Next step up form Siemens 55s
26-04-2013, 04:57 PM
As above any recommendations as not sure if my 55s are gonna be man enough now.
26-04-2013, 05:17 PM
83s then
26-04-2013, 05:33 PM
26-04-2013, 05:57 PM
I'm sure someone will have some for sale, there's 72s too iirc.
What power are you planning for??
26-04-2013, 06:02 PM
Quote:
Originally Posted by
3drRich
I did mention that in your engine spec thread but it must have been overlooked
If you need big injectors then your going to be forced in to aftermarket management until a suitable replacement is found for 83's that you can run on Ford ECU
26-04-2013, 06:19 PM
I want 450bhp now so spec is the same except think its gonna be gt30 and 83s.
I remember you mentioned it brammer but still abit new to all this siemens and gt bits lol. So can i not run 450 on my standad ecu?
Im gonna ring motorsport developments tomorrow to pick there brains about whats best before i go any further.
26-04-2013, 06:25 PM
3drRich
Of course you can, and more
26-04-2013, 06:26 PM
Bodger of Blackburn
run some 60's then, enough for 450bhp.
had no problem with my 2.1 zetec turbo on a gt30 on 2BAR.
26-04-2013, 06:28 PM
Bodger of Blackburn
if your fuel pump is man enough and i ran an 8BAR one, then you can crank pressure up to max pressure minus boost pressure peak, the siemens can take extra pressure well.
the 60lb's i mentioned would do 900cc at 6BAR above boost pressure.
26-04-2013, 06:30 PM
Ok thanks. I will see what motorsport developments say as hopefully i can get my injectors from them
26-04-2013, 06:36 PM
You have got L8 in it Rich yes?
26-04-2013, 06:38 PM
Staffi
I assume so bud
Its standard 3dr!
26-04-2013, 08:07 PM
if its standard then you'll be on a L1
26-04-2013, 08:44 PM
SLOW LEARNER
Il have your 55s if your upgrading!!!!!
26-04-2013, 09:06 PM
MSD will soon have a replacement lined up for the siemens apparently
26-04-2013, 09:18 PM
Live long and prosper!!
LHD220Turbo
Matt did you run 55lbs?
26-04-2013, 10:02 PM
yes mate, still got a set somewhere at home
I thought the limits of 55s were the same as greys max out 450 ish
27-04-2013, 07:30 AM
I virtually max'd a set at around 440 on a T series turbo which is why i wouldn't touch 55's on a GT setup
27-04-2013, 03:38 PM
LHD220Turbo
cortina? got me thinking
01-11-2015 06:53 PM
timsrs
22
24-09-2015 08:14 PM
Flatlinedan
18-09-2015 12:41 PM
cos elle
16-09-2015 06:37 PM
Rich Coveney
Ford Mondeo Including ST
15-09-2015 05:39 PM
