arch mods on 3dr 6 degree beams??????
Old 22-04-2013, 09:11 PM
  #41
throttle jockey
throttle jockey's Avatar
Old 22-04-2013, 09:13 PM
  #42
The Underdog
you cant fix stupid
The Underdog's Avatar
Originally Posted by B13 JUS
I had the same problem with my 3dr. When you are pushing the tca's out to give it more camber, this makes the wheel move back because of the standard arb.
So the more camber you want the more the wheel will move back and will catch the kit.
I've had to spacer my arb to push wheels forward again.
This is making my car tram line so I think the only option is to return back to standard tca's and remove all spacers from my arb then buy some top mounts to adjust camber than way.
3drs are a night mare because of the kit.
this makes sense as to why you are having wheel centering problems reading this. your caster is being ruined with the wheel being pushed back.
Old 22-04-2013, 09:14 PM
  #43
throttle jockey
front wheel
Old 22-04-2013, 09:18 PM
  #44
Rsmat
300+
Rsmat's Avatar
Mine was also like that with 215's ... Honestly try 205's before cutting anything mate
Old 22-04-2013, 09:19 PM
  #45
The Underdog
you cant fix stupid
i dont fully know what you have fitted to your car but it sounds like a waste of time on the front at least. your adding positive static camber but gaining negative caster which will reduce dynamic camber. probably best left stock or get adjustable top mounts
Old 22-04-2013, 09:22 PM
  #46
Rsmat
300+
Rsmat's Avatar
When I fit my beam.. Do I have to alter the front as well ?
Old 22-04-2013, 09:26 PM
  #47
The Underdog
you cant fix stupid
i would assume only if you want to. unless your tracking your cars i dont see the need for adjustable parts unless its to reduce tyre wear from them being lowered?
Old 22-04-2013, 09:38 PM
  #48
Rsmat
300+
Rsmat's Avatar
Cheers mate .. 6degree beam will make it handle better and use the full width of the tyre tread mate .. And gain plenty more grip.. So unless i go on track I don't need to alter the front ?
Old 22-04-2013, 09:39 PM
  #49
throttle jockey
certainly will give a try thanks mat
yes agreed will be going for top mounts for sure to get some caster adjustment thanks for the advice dai.
Old 22-04-2013, 10:39 PM
  #50
The Underdog
you cant fix stupid
personally i dont think i would alter the front. i dont know what your standard camber would be but if you add positive camber and only use on the road it will just add to tyre wear on the inside. somebody else may say different but for me id say no.
i can understand the rear to add grip for the power your running so you can put power down in straight line better. assuming your reducing positive camber on squat that is and not increasing it.
theres prob more experianced brains on here than me so wait for more input.
Old 22-04-2013, 10:42 PM
  #51
The Underdog
you cant fix stupid
that should read your adding negative static camber sorry
Old 22-04-2013, 10:45 PM
  #52
Rsmat
300+
Rsmat's Avatar
Cheers Steve .. It's only a fast road car so may leave the front as It is .. As I've had no probs with it
Old 23-04-2013, 09:35 PM
  #53
Rsmat
300+
Rsmat's Avatar
Bump....
Old 23-04-2013, 10:55 PM
  #54
The Underdog
you cant fix stupid
Bump....
mat iv noticed that when geometry is mentioned on here threads go quiet very quick lol.
not many understand and the guys who do i think keep quiet to keep the secrets to themselves. hopefully you get more experianced advice soon
Old 23-04-2013, 11:11 PM
  #55
Rsmat
300+
Rsmat's Avatar
Ah thought so mate ... Cheers Steve
boeb
09-01-2020 05:11 AM
01-11-2015 06:53 PM
Brickhouse
14
03-10-2015 07:28 PM
SMILER258
28-09-2015 09:04 AM
DavidK
27-09-2015 02:55 PM
Quick Reply: arch mods on 3dr 6 degree beams??????
