need some help regarding compression readings
Old Apr 16, 2013 | 11:10 PM
rsguy's Avatar
rsguy
Default need some help regarding compression readings
need some help regarding compression readings.
my engine compression rate ( cr ) of my engine is 7.4:1 im not sure what compression psi readings i should get getting with that rate. can anyone tell me what psi readings i should be getting please. and if my test psi readings look ok.
i done a compression test today and got these readings .
dry test
cylinder 1 - 130 psi
cylinder 2 - 130 psi
cylinder 3 - 130 psi
cylinder 4 - 130 psi
wet test
cylinder 1 - 140 psi
cylinder 2 - 135 psi
cylinder 4 - 135 psi
thanks
Old Apr 17, 2013 | 11:33 AM
stevieturbo's Avatar
stevieturbo
C**t
The fact they are all very close together is largely all that matters. The engine can be deemed fairly healthy
Old Apr 17, 2013 | 12:15 PM
rsguy's Avatar
rsguy
ok thanks steve.
i thought possible worn rings or bores as my engine is thowing out white/grey smoke when warm and smells of oil.
done a leak down test and its saying cylinder leakage moderate 65% on all cylinders.
also tryed just useing 100psi of air i hear the air escaping out of the engine dipstick & oil cap.
this would suggest Rings/cylinder seal.
however the compression reading on all cylinders do look all close together so i think maybe the rings are ok.
im thinking maybe valve stem seals. however im not sure if worn valve stem seals would cause blowby in the crankcase.
Old Apr 17, 2013 | 12:26 PM
stevieturbo
C**t
As I said, only deemed healthy. You never mentioned any symptoms of a problem like you just did now.
A compression test is just that. It won't always tell you of a ring problem leading to oil use or smoking.
Leakdown of 65% isn't great tho.
Assuming all tests conducted correctly etc
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
Iain Mac
Sep 30, 2015 09:39 PM
