Any audi people on audi a4 tdi oil leak
As above noticed oil underneath my car today on closer inspection it seems worse then I thought passenger side of engine is covered in oil as are wishbones ect puddles everywhere! My question is I think it's coming from one of the pipes below the oil filter and ideas what's these are thanks?
Assume that is the 1.9 TDI probably an AWX engine then that has probably been caused by careless oil changes. Your picture shows the oil filter / cooler housing. The filter is a paper cartridge and will slop oil everywhere if a careless knob does the work (is it you ).
I'd clean it all off and then look for a leak.
You need to clean it all off then so you can see where it might be coming from.
A can of gunk and a jet wash or an aerosol or two of brake cleaner and loads of kitchen roll / wipes.
On the off chance, check the filter housing cap is tight, it is black plastic and about 70mm to 80mm in diameter.
i'm fairly sure the oil feed pipe for the turbo comes from that side of the engine and runs around the other side to the turbo, i've kown these to leak before so it could be that,
the oil usualy comes flooding out if thats what has failed bur it possible just a slight crack in the pipe,
best bet is as already advised, clean it all up and trace the leak
Adam Graham
06-09-2015 06:04 AM
