What sort of power??
What sort of power can be had from a Cossie YB running:
T34, Scorpion Exhaust, Group A Filter, RS500 Intercooler, 14mm Plenum spacer? currently running standard 4x4 blue injectors.
and Potentially, what could it safely run with bigger injectors an a remap without any other work?
depends on what turbo you have t34 .48 , .55 , .63 ? and depends how much you want to take out the turbo as rsmat has 400bhp out of a t34 .48 but he has a diffrent shaft i think , the t34 .63 380/400 bhp or i think it will do more but wont last long and the t34 .55 is an inbetween , hope that helps
It is yes, I am looking for around 330, not sure what size the turbo is, will have a looki in daylight, is 330 achievable with this setup and some better injectors?
you will need 803 green injectors , t34 .48 , rs 500 intercooler , (not sure if you need the spacer but can only help , chip (stage 3), dump valve, group a coil,
parts you may need but i am not 100% sure about
3 bar map sensor
spark plugs to suit bhp
better ht leads
breather tank
all i can think of just now
3 bar map sensor
better ht leads
breather tank
deathrider666
28-09-2015 06:12 PM
