wilwood slave cylinders
what size master cylinder are people using with them?
wilwood reccomend .75 but im not getting enough travel at the slave end
its been bled loads of times
You can get more travel a variety of ways.
Alter the pedal/master pivot point to give the master rod more travel. Use a larger diameter master. Use a smaller diameter slave. Or alter the linkage after the slave.
As for bleeding, shouldnt be difficult unless either master or slave is orientated in such a way that air can get trapped.
