Are these parts still available from Ford?
Over the last week or so i have been stripping my saff down to the bone and then re-building it with the engine out of the rwd Escort.
I removed the rack and track control arms as they were fooked but have had to cut-off the big washer things that go either side of the outer tca bush as the metal sleeve thing inside the bush was corroded to the arb!
I thought i would have some of these big washer things somewhere but can't find any
Are they still available for Ford?
Cheers Spadge...
Cheers Spadge...
not new ones mate, but have a couple of usual condition ones.
There easily available from Fords, but as you say the parts man at your counter dont know shit, im sure someone on here will have a part number you can just simply walk in and order 4 of them
Jim i've no doubt they come with the tca's but i'm not buying tca's for 2 washers!
Ryan send me your shonky ones mate i'm not fussy
Originally Posted by Ryan
no sapdge you can buy them singly, i did for my RST.
shall i add it to your tab?
One day i'll have something you want
Im a trader im aloud to
I'll speak to you tommorrow on MSN and get your addy again
although i should know it by now
Ryan i'll go to my local factors tommorow and see if i can get any 1st
Then have a rummage through the shed
Then if all else fails give you a shout
i SOOOOOO need to learn how to do that
ok mate no probs if i remember rightly there about Ł1.20 each retails.
nice shiney gold colour too, bit too bufty for you, best send me those down and i'll send you up some nice "used" ones
spadger doo
they are not same as normal shonky saff ones
ya want granny ones or proper cozzy ones that come with a plastic cover aswell
normal saff ones are curved these are flat sectoin ones ya need
it asmases me how many ppl fit shitty normal parts to proper cozzys there totally diffent
normal tcas Ł14 each
cozzy ones list at Ł56 each
tcas that is
tcas that is
My mate has just bought a set of these ARB washers with plastic caps as his were all odd and making his geometry pissed on the front. They came for not much money IIRC, something like Ł3 a washer and cap.
washers/caps the same as a normal saff
washer front 6172539 Ł1.34+vat X 2
plastic cup front 6137668 Ł1.68+vat X 2
washer rear 6172540 Ł1.24 + vat X 2
rear plastic cap 6137669 Ł1.68 +vat X 2
go and buy them from your dealer
brom, i was under the impression that only 3dr TCAs were different, and that saph ones were same as shonky saphs (likje mine )
Originally Posted by St3V3_C
Mine doesn't have the plastic bit - nut, big washer, bush only. Should the Escort definately have these too?
no theres a few diffent tca
theres 3 types of tapperd types castle nut 3door type
there the standard saff tca with rubber bushes and domed washers and 10mm bolt fitting
theres the cozzy type with larger ball joint presed in bushes in the roll bar and a 12mm bolt hole in the bush
and theres a 4x4 tca aswell
155lee
14-09-2015 07:37 PM
borboyous
22-08-2015 11:17 AM
