Cossie 4x4 Question?
18-03-2013, 08:55 PM
Right I'm having a bit of a mental block......
My dads got a 4x4 2.0i DOHC Sierra Estate and we're looking to convert it to cossie this year. Apart from engine, turbo, ecu, loom, front brakes, exhaust etc, what else is needed? Being the 2.0i 4x4 it's already got the 3.9 diffs.
Anything we've missed???
18-03-2013, 09:03 PM
18-03-2013, 09:04 PM
think the gearbox will be the wrong ratios for a start
18-03-2013, 09:07 PM
Good thinking batman...forgot about that
Quote:
Originally Posted by
CHUNKYS RS
Arn't the gearboxes the same just the donut being different?
18-03-2013, 09:16 PM
1st to 200 without NOS
CHUNKYS RS
Not true.
Front hubs and driveshafts are different too btw.
18-03-2013, 09:19 PM
The bell housings are different.The starter motor will be in the wrong place.
18-03-2013, 09:21 PM
YOREVOL
2.0xr4x4 box has smaller weaker internals iirc.
18-03-2013, 09:25 PM
sticky i would have thought the full brake system ,loom ,sensors eu etc
radiator,intercooler,engine mounts[?]map sensor,
18-03-2013, 09:28 PM
Again, not true! 2.9 is on the other side as I recall
18-03-2013, 09:36 PM
Thought twin cams and I-4's were different bellhousings again ?? diffs wont be LSD
18-03-2013, 10:14 PM
Martin-Hadland
True. Xr4x4 boxes opposite hand
18-03-2013, 10:21 PM
Sorry mate but that is wrong! I have had 3 DOHC 2.0 4x4 Sierras in for breaking over the last couple of years and all of the starters were on the same side as a Cosworth 4x4 box and all of those boxes bolted straight into the Cosworths we fitted them to.
Edited to say I think I read that wrong and you were agreeing with me?
18-03-2013, 10:39 PM
martins right my racecar has a 2.0 xr4x4 box in it at the mo
the clutch arm pin and the tailshaft need changing that is all ( if using a late 4x4 saph /escort cosworth propshaft)
steve
18-03-2013, 10:45 PM
Apparently the 3.9 front diff is very weak, so you may be better using cosworth 3.6s?
18-03-2013, 10:52 PM
if it was me i would be keeping all the running gear matched i would not mix ratios
18-03-2013, 10:55 PM
standardish power the 3.9's will be fine
steve
18-03-2013, 11:02 PM
matthewpickup
You can't mix them, it wrecks the gearbox if you do.
18-03-2013, 11:10 PM
Paul_RS
thats the reason i said i would not mix them
19-03-2013, 06:05 AM
matthewpickup
thats when using a front 3.6 and a rear 3.9 you run a drop off gear in the transfer box
19-03-2013, 09:04 AM
The Youth.
steve
Thanks Steve, I thought I read somewere it was the same with a small mod.
If I had my way, it would be 2wd
19-03-2013, 10:16 AM
Zee Germans are coming
Best bet is to get a full 4x4 and put everything from the cossie in to the estate
There must be plenty of cossies to break
19-03-2013, 12:11 PM
Martin-Hadland
Or well i was nearly right.So a 2ltr dohc gearbox will fit a yb??
19-03-2013, 12:13 PM
Arnt the rear suspension arms and shockerd on an estate different.
19-03-2013, 01:41 PM
Correct, estate has 'Concentric' shock absorbers.
OP, if you do a search there is a thread on here, as a member here (ForeignRS) done this.
Martin
Music & Car Audio Chat
03-09-2017 01:24 PM
Marino
12-09-2015 11:10 AM
Escortdriver1
06-09-2015 10:12 AM
Adam Graham
06-09-2015 06:04 AM
