WTF, is this legal
1 Post
WTF, is this legal
Rover 100 with 420 GSI 2.0L TURBO ENGINE CONVERSION - Rear Wheel Drive!
http://www.ebay.co.uk/itm/Rover-100-...00875898177%26
Only issue is getting it on the road it may have to be inspected as per kit car and end up on a q plate. Z car minis end up in same position. This is expensive and could involve a lot of changes to comply. Be a good track day car though.
Reckon it could be a good bit of fun, wouldnt buy it though
There’s a bloke called James (JM Motorsport N.Ire) that has a Nova with 2 engines in it, boot and under the bonnet, not 100% sure on how he pass’s MOT either
wouldn't need inspecting by the dvla at all, just fill in the new capacity and engine number, don't see why it would need a friendly mot either, as long as it complies then it will pass, Ithe engine position has no bearing to the mot as long as it isn't falling out!
steve
steve
The new rules are totally different now and the cutting of the shell to fit the engine removes the points that the shell provides for retention of ID this then leaves the car requiring a full test to get a q plate. As by modding the shell and changing suspension and engine leaves the car with no ID, the rwd converted escorts and fiestas would also be in same position now. You may get away without declaring, if picked up by vosa then a test would then be requested, but if you read this link there is a lot to consider
http://www.theminiforum.co.uk/forums...st-list-hints/
Post 16 states how this one got caught out
