Camshafts
Camshafts
Hi all,
Is there anyway to identify standard camshafts on a 2wd Yb other than taking them out and measuring them?
Not sure if mine have been changed or not! (3door)
Thanks for any-all info.
My Best, T.
My Best, T.
Thanks rich, will have a look tomorrow. In your opinion what if any difference does a cam change above standard have on lower end torque/power.
Cheers, T.
Cheers, T.
All standard, apart from valve springs, well I suppose not really that standard nornal stuff 0044 fuel pump-071 plugs-atb diff-7.8 cr - looms up-rated-drive-shafts-train uprateed. the usual 500 intercooler/rad/turbo cooler- along with group a coil.
t34 turbo (but not as most know it im told )
Inducer comp- Major-3 inch
Minor-2.122
Turbine
major -2.555
minor- 2.126
Getting 7psi @3000 rpm everyone else seem to achieve more? but I wonder if this is down to the fact that a T34 exducer is 69mm where mine is 76mm?
Looking at all posibilities, as I don't think a journal bearing turbo is that far behind a ball bearing item of the same stock.
The forum goes dead when knowlegde is limited !
My Best, T.
Minor-2.122
Turbine
major -2.555
minor- 2.126
My Best, T.
foreigneRS
Technical essay Archives
20-07-2004 11:29 AM
foreigneRS
20-07-2004 11:06 AM
