Replacing fuel lines on saph...
Right my saph fuel lines have seen far better days when I got car there were sections that have been replaced with fuel hose (1ft) here and there, now Im about too fit my BOA engine and have to alter fuel lines anyway so want to just replace for new.
My question is whats best to use as a replacement copper or braided fuel lines?? and what diameter?
Cheers WES
Cheers WES
cossie fan (unluckerly)
I did my hole fuel system in braided tank to rail then back to tank all aero quipped had my rail and tank modded with fittings as well so not one hose clip
For me it's better this way as it looks better plus my lines are Teflon stainless braided so will last far longer than i will lol
All depends what your after Teflon braided is best but you can only use it with fittings!
There a few ways of doing it I just took that route as its easy and looks good you can replace the steel pipe or use copper plus there is rubber braided
imo i think there would be very little life diffrence from braided to copper , copper would be cheaper and do the same job but braided looks cool
lol i beleve you , but to the cost is it worth it ? as copper pipe is what no more than say £25 ? and look how long copper brake pipes last lol
I only went for the Teflon so I could use fitting over hose clips but is not as costly as people think!
I had my rail and tank modded for fittings made a fuel cradle got a new reg then a few fittings at a time and the hose I needed all in less than 400 with the reg costing the most
just had a little read about the two and some people are finding problems with the teflon but this happens with everything , one guy recons copper will last 20 to 30 years lol dont know how right that is , end of the day its down to choice and what look you want
that is the biggest factor at the end of the day and they all do the same job lol
got it in one as i cant see how they would have problems , they said it gave them problems when the lines were dry for a bit then when used agein thats when they had problems , but in the real world they will always have fuel in them so no idea what some people are upto lol
copper life imo is down to weather you drive in , but i read that is ment to be 20/30 years but i would say 10 just to be safe and tbh its not hard to do
Wes im using 10mm aluminium black powder coated fuel lines from james listers motorsport you can use flexi pipe pushed on with O clips or flare the ends and use an-6 fittings where you want to
Its £9 + vat so about £11 for 4 metres![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
David
David
Wes
