BMW E46 320d experts on here?
The turbo went on my 320d back in july. i got my old turbo reconditioned along with the injectors, ever since its been very hard to run, an the MPG guage in the dash goes of it head when rev'd over 2k? boost doesnt seam to come into around 3k? an when you rev it hard on boost it pumps out black smoke, i check boost pipes no leaks ect, i was told to block off the small pipe that goes into EGR an see if it stop smoking, it didnt smoke as bad but still didnt fix the problem, iv had it plug in an nothing came up. has anyone any idea what could be wrong with it?
Andrew
Andrew
Possible that you have the old 'loo-roll' type oil breather/separator that clogs up, that can also destroy the turbo/make it smokey. You can replace it pretty easy with the newer 'vortex' style breather from BMW themselves for about £25!
See here:
http://www.bmwforums.info/general-gu...20td-320d.html
Also, EGR maybe sooted up inside? They get ridiculously clogged up.
See here:
paul
i have the breather fitted aswel, cleaned egr aswel,
DavidK
Sep 27, 2015 02:55 PM
