Single Mass conversions ( Upate inside )
Whats the score with these?
Do the cause gear box failure or not?
I'm in need of a clutch for my Cupra R, It started slipping on boost.
I'm thinking of a SMF but there are bad tales on the net.
Anyone have any experience they would like to share?
big floppy donkey dick
dont buy a cheap one !
the DMF was there for a purpose, make sure you put a sprung clutch in there
"it destroys gearboxes" is bollocks, pure abuse breaks them
shoddy ones that are poorly balanced can cause vibrations etc, just obvious really, hence my first comment matey
plenty quality ones available for not a big load of cash, and you should only ever have to buy it once!
cossie fan (unluckerly)
I only work on big stuff but are van shop dose a few vans with duel mass fly wheels and they rate them as shit lol and a fair few things get converted to normal!
competant bodger
ive only ever personally experienced one problem with a smf conversion and ive fitted hundreds and it was on a 2.4 transit the crankshaft broke in two due to a harmonic imbalance which is one of the reasons the dmf is fitted in the first place, i have fit other conversions to transits before and since and never again seen it happen so it may have been a freak occurence
Botters, Thats the sort of things I have read.
I have been told the Valeo kits use large springs on the friction plate and almost feels OEM.
Fitted SMF to my modified (400+ Nm) mk3 Mondeo diesel
Fitted organic fast road clutch, hd backplate 30% increased clamping force
with sprung plate
drives smooth and ive had no problems in 2 years (driven hard)
Agree with cossie seans comments about sprung plate/ sh1t ones
if you are going to the trouble of dropping the gearbox may as well do the SMF, and the parts of the clutch inc CSC
with sprung plate
Hi mate own and run a garage for a number of years now so have fit more than i would like to remember, SMF are the best thing to fit, Duel mass are gearbox killers as the amount of vibration they send into the box down the main shaft when they have play in them is unreal, they are known for killing alot of the VAG gearboxs (german) and SMF is the only way to go in my mind. The reason for duel mass in my mind is for a smoother, less shocked gear change as the spring/grease system inside them absorbs the impact which they are good at but once they go wrong they dont half F@@k things !
Ok so I have ordered the Valeo kit now, Just hope it can cope with the stage 1 remap,
Ive never fitted a csc, Do you have to bleed the hydraulic system after fitting?
Bodger of Blackburn
feel of clutch is the same and has handled the 170bhp remap for just short of 18 months and still going well.
mine cost about Ł360 with slave cylinder.
i have a Valeo SMF and clutch kit fitted to my remapped bora, apart from a slight clutch chatter around 2000rpm under load, it's spot on.
just paid Ł343 including the CSC, carparts4less is great.
Im pretty sure its part of eurocar as the site is identicle
The kit turn't up today, Looks well made.
The CSC only has an inlet, No bleed nipple so I guess it's bled before the CSC.
How the hell does the air in the CSC get bled if the nipple is before it?
This was why I asked if it needed to be prefilled with fluid before fitting the hydraulic line.
Mate trust me i fit about 3 - 8 clutches a week, you dont pre-lube it just fit it and crack the nipple, once the fluid has come out give it a few pumps and then crack the bleed nipple, the air will always find its way to the top ! a lot of vans are like this, did one today on a Vauxhall vivaro same one nipple BEFORE it goes to the csc
Well I spent today fitting the conversion,
I can now confirm its on my 'NEVER TO DO AGAIN' list.
Working on the floor is now joke, I've done a few Golf 1.8t Clutches in the past and they have been a doddle!
They were all 5 speeds though, The extra size and weight of the 6 speed is really noticeable.
The box is in and all bolted up but I ran out of time due to waiting for some help lifting the box back in.
Need to bolt up the drive shafts and tighten the anti-rollbar then bleed the system,
Hopefully there won't be any dramas with that and it will be back on the road tomorrow.
I will never do another one of these on the floor.
EDIT: I forgot to say, I had problems getting the gearbox to close up on re-fitting, Turned out to be the CSC stopping it.
Because they are spring loaded we couldn't get it close up. Ended up bolting it up and pulling it on that way.
LOL, I can imagine.
The CSC really caused a head ache, I pulled the box off twice and rechecked the clutch alignment because it would go on but just wouldn't close.
After examining the old unit I realised it was spring loaded. I could see that the CSC had been in contact with the pressure plate so we decided to wind the box on with a bolt.
Went on fine after that. Hopefully it will bleed up ok and the rest will go back together fine in the morning.
Definitely not in a hurry to do it again.
Glen, That's a scary thought.
I have heard its mainly diesels that suffer with these conversions.
What do they actually adjust within the map?
