vw bora tdi pd engine power loss problem
#41
If its a 150 they have some serious cam wear issues two people i work with have both had to have new cams and followers. Once the case hardening has worn through they wear like butter!! Not saying this most likly the problem just know its an issue!!
My old pd130 golf was a brill everyday car
#42
big floppy donkey dick
when cams go they tend to put swarf everywhere and destroy the buckets too.
head off, and change the oil pump too got good measure, make sure everything is super clean!!
with regards non starting......
pull 1 injector plug off at a time, and try to start it, if 1 injector goes down it wont let it start, this will identify the dead injector and it will start on 3 pots
#44
I had a fault on mine where loading the car in sixth uphill on the motorway would stick the car into limp mode. Puzzled me for a while and turned out to be a split boost pipe.
And yesterday mine just cut out, would only crank and not fire, but brought no errors up. I'm thinking in tank pump - lets see! This is a BKD.
Nearly forgot about the intake manifold flap, that went last month too. Think I need to clue myself up on deleting the EGR, the gunk inside was horrendous.
The joys of VAG ownership
egr has been off with the turbo and cleaned out, was pretty sooty, but not the worst i've seen.
#45
Hi mate iv also got a bora pd 130 mine did the same thing after diagnostics turned out to be a injecter loom fine after that though lol.
#46
The pipe that split on mine was an elbow off the cooler. Started really small.
Put a new pump in last night. Took some cranking to get going again though (longer than it took to fit the pump!)
#50
either/or, i didn't end up with VAG-COM anyhow, just got very curious about the amount of turbo/air noise when in boost, so looked at boost pipes which seemed ok, then thought i;d clean the crap off the intercooler from the outside and thought i'd run some soap through the core to clear any oil out. That was the moment where the hose pipe couldn't get it full as the end tank had come away from the core and leaked out.
it is up on power, down on noise and seems to not be entering limp home mode which makes sense as the MAF is actually reading the air that is entering the engine, not like the loss under load and the extra air drawn in un-metered on cruise.
if i'd have driven it more i'd have noticed the increase of noise of air from turbo as it got worse, women, never notice things like that.
cheers all for your help
sean
sean
Stu @ M Developments
41
21-08-2015 06:47 AM
