Piper/Hales court case
#41
Testing the future
i'm saying that the specific issue with the car as has been detailed is that it often doesn't go into gear and is therefore in a false neutral, a situation where a rev limiter would prevent damage.
any other situation is irrelevant. of course sticking it in a wrong (lower) gear may still cause a mechanical over speed which a spark or fuel cut type rev limiter cannot prevent. equally, an asteroid landing on the engine from outer space would damage the engine, but it seems that neither of those things were likely to happen.
can i not write in english, or can you not read it?
sorry to the OP, this is dragging it a bit off topic
#43
Resident Wrestling Legend
no, of course i'm not saying that - i'm not stupid
i wasn't saying your version of events wasn't true, i was simply asking if over reving the engine by putting it into 3rd when you were looking for 5th would prevent engine damage, you just took some low hanging fruit when you mentioned asteroids
but yes, i know what you meant when you said it and i'm not upset because you put some nice little on the end
back to the question of "you bend it you mend it" if it's a mates car i borrow then of course, that stands to reason, but if it's a car you are hooning about in for a publication, the person who fills the forms in should have made it clear who would be footing the bill if things went tits up, either the magazine or the owner, certainly not the test pilot because said test pilot should know his limits AND said test pilot should have been properly vetted by the employer before letting said test pilot out on a test flight of some very expensive machinery
muz
30-09-2015 08:29 AM
