need a bit of zetec turbo breather advice please :)
need some advice on my zetec turbo setup
so far i have had 3 hose conectors machined in to the block 1 for the turbo return and 2 at the back but didnt bother with the sump yet
i was thinking of blocking one off at the back of the block and installing another in the rocker cover so a pipe goes from the block to the rocker cover then the oil will go up the pipe and the airea in the rocker cover/cams will act like an oil seperator then the oil will return back to the sunp and the gas can escape from the original zetec breather hole in the rocker cover
that basicly emulating the cvh system
if some one could post some tryed and tested systems where u dont have to keep emptying catch tanks etc.. ie maintenence free then let me know
out of the whole conversion this is the only thing i havnt put much brain power in to
lets see blue sump
pink rocker cover
green block ?
so i need to blank off one of the block breathers (i had 2 put in) and install some sort of tank conector at the bottom of the sump under the oil level ?
or could i use the other breather in the block for the oil to drain back?
pink rocker cover
green block ?
blue sump
pink block
green rocker
you dont want the sump connector under the oil level unless your goign to use aeroquip propper lseal like
push on pipes will leak
pink block
green rocker
