F.A.O any plumbers help needed (TIFF so im told lol)
im after a bit of help, i have just fitted a new tank and cylinder as there was no hot water pressure in my house and there still isnt
so i have bought a new system boiler which isnt fitted yet but im wondering is there any pump i can put on the hot water pipe to give it a push ??? or would a shower pump do the same job ???
please help as i have just got a huge bath with wirlpool and it is going to take 3hrs to fill it
Hi Rob, You can fit a pump in your hot press which will do both hot & cold water. You will need to fit a surrey flange into the top of the cylinder to stop the pump drawing air down the expansion/vent. These pumps are a few hundred quid for a good one. A shower pump would be a bit small. You will also need at least a 60 gallon storage tank. If you have en-suite and down stairs loo you might need a second one as the pumps don't half pull water. If you need to know anymore let me know.
i have a 144 litre cylinder with just the bathroom, kitchen sink and washer runing off the hot water but there has never been any pressure
i have moved the cylinder and tank into the loft but as the cylinder was a bit on the big size i didnt have the head room to to put the tank much higher, it is basicly right on top of the cylinder
i have bought a system boiler to heat the water aswell would that give it an extra push ??
do you have any links on these other pumps ????
Any plumbing/builders supplies would have them. Is your supply to the cylinder from the storage tank and from the cylinder to your bath 22mm-3/4" ? It should be. I've seen them in 15mm-1/2". On a gravity system the pressure would be very poor. Another cause could be an obstruction in the supply somewhere. I pulled bat bones out of a pipe one day. Check these before you waste money on a pump.
its head pressure your suffering with you will get 0.4 psi per foot and that is from the water level in the tank to the outlet of the water from the top of the cylinder ........if you are really sensible you will put the cylinder back where it was and leave the water tank in the loft and the water pressure will be fine
you can increase the volume slightly by increasing the vent volume from the cylinder...........instead of going straight up with the vent run it atangle and halfway up it go from 22mm(which it should be run in)to about 56mm and the back to 22mm before it loops over into the cylinder(basically it beats the drop in the tank when the tank level gets low) this will stop the spitting of water from the hot bath tap(or all those run in 22mm) on the down services hot water
Pugo
PS better still, get a bl00dy plumber in to sort your diy nightmare out
Pugo
also it dont matter where the cold tank is in relation to your cylinder it only matters about the cold tank to get pressure so if it cant go any higher in the loft then nothing you can do
if your description was right you could have the cylinder higher than the tank
Pugo
pugo what are you on about mate, the head of water is from the level in your cold water tank to your hot water tap, it doesnt change the head / pressure where the hot water tank is between them the only problem you can get with the cold water tank and hot water cylinder being close is sucking air down the vent.
If you want to do the job right the cold feed to the cylinder should be one size bigger than the hot out let, ie cold feed 28mm hot out let to taps 22mm.
cheers dunc
cheers dunc
Originally Posted by Dunccoss
pugo what are you on about mate, the head of water is from the level in your cold water tank to your hot water tap, it doesnt change the head / pressure where the hot water tank is between them .
cheers dunc
cheers dunc
is your supply to the cylinder from the storage tank and from the cylinder to your bath 22mm-3/4" ?
you can increase the volume slightly by increasing the vent volume from the cylinder...........instead of going straight up with the vent run it atangle and halfway up it go from 22mm(which it should be run in)to about 56mm and the back to 22mm before it loops over into the cylinder(basically it beats the drop in the tank when the tank level gets low) this will stop the spitting of water from the hot bath tap(or all those run in 22mm) on the down services hot water smile011.gif
thanks for the advice lads
also lets say the tank is on the roof of a block of flats and the hot tap is on the ground floor........the cylinder is fed with 28mm and the take off is 22mm
now would the pressure vs volume ratio at the tap be the same if the cylinder was on the 10 floor or the 2nd......er nope
so yes it does..........or have you not heard of frictional loss through pipework????
Pugo
anyone who can install a cwst and cylinder does not nned to be told that that the tank has to go go higher, hes a DIYer not a fucking baby.
also how much flow do you think you lose from having another length of 22?? (i.e from first floor to the loft) fuck all
also frictional loss occurs with elbows and bends , not just the size of the pipe ,so now your talking about the actual pipe runs themselves. not all cold feeds are straight down!
chill out lads was after a bit of advice lol
i always knew it wasnt ideal having em both stuck in the loft but i have no room for it anywhere else so thats why i just wanted to know if they did a pump for the hot pipe
thanks for the advice tho lads ill lookfor a pump this week
pugo
no no its you who is contradicting yourself.
i said the cylinder can go anywhere (obviously not higher) to the tank and the flow and pressure is the same, then you come along with your bit about how you get better flow the longer the cold feed is as the bigger pipe (cold feed) has less friction
so i said this isnt true as the 'big' cold feed pipe could be full of elbows, so youd be better off having a small cold feed and long straight hot pipe.
ive read your posts in other topics and your very hard to get through to, so im not gonna bother arguing any more
and yes i know that bends increase frictional loss....i was trying to keep it simple so that YOU would understand
fook me,,,it ain't that hard......the bloke has already got problems and now your shooting from the hip
Pugo
PS its better to give somebody all the info or no info at all.it tends to help them in the long run
also how many cylinders actually have a 28mm CF probably 1 in 10, this guy said he dont so again your theory of putting it in the first floor is a waste of time
your making yourself look stupid dude the bloke who started the thread even agree's with me.........and i thought you weren't gonna argue with me or is this just another of your amazing contradictions
fook me and you had the cheek to say i was to hard to get through to!!whats your middle name,? fookin titanium
Pugo
PS your waffling now
Pugo
so no it wouldnt be better on the 2nd floor
oh and i take it ''your waffling now'' means oh yes rob, actually your right and i cant think of anything else to say
and NO ' mr contradiction' i do not think your right.........who you trying to convince here????? yourself or the rest of us [quote]
Posted: Sun Mar 13, 2005 10:03 pm Post subject:
DIYers sticking together, aye?
fook me . remind me not to ask you to plumb anything in you fookin chancer
Pugo
Originally Posted by 'pugo'
yeah put your cylinder where you like mate.......put it in your shed if ya want
Pugo
Pugo
i origainally said it can go anywhere because of this....
and being a chancer for saying its ok for cylinders to go in lofts? no mate its called plumbing in the real world. so tell me if you was asked to put a cylinder in the loft due to no room ANYWHERE else suitable, youd walk away? ''sorry love these types of houses cant have hot water''
are you going on about..............i never said it can't go in the loft.....you offer a bloke half the advice he asks....even he agreed
....i have twin cylinders mounted under my tanks in the loft(which i fitted)
is this all a bit hard for you to understand ????
you were obviously talking crap when you said the cylinder can go anywhere with no affect at all , which you have already agreed was wrong as you now agree about frictional loses, you never mentioned to the guy (who is a diy'r) something fookin obvious about the where the cylinder should go ..., you have no knowledge of his understanding or technical abilities when it comes to plumbing
so believe me if i ever needed a plumber(which i won't) or indeed if the people that read this thread need a plumber.......i would guess your number (especially with your attitude) would be the fookin last one they would use
you said
yes....so here is your post....he may have took it as dont worry mate fit your tank at the same level as your cylinder for all you know
are you actually understanding any of this or are you just going to argue for the sake of it
Pugo
Ps ..have you thought of changing trades??????????
Pugo
FFS you dont read english very well, his question werent ''where shall i install my cylinder'' its already installed!!, he thought because the tank was directly above the cylinder, he thought this was his problem. i was simply stating it wasnt.
as for my attitude, im not the one arguing with an 18 yr old gas fitting apprentice over the internet.
can see what you mean pugo but i think he also has a point as it is already up there so im going to have to live with it.
my house isnt that big and the bath was huge so it was the only option i had. so i think ill just get a pump to give it a bit of a push
thanks for the advice lads now i need a pump any 1 do me 1 cheap ???
