Correct spark gap...!
Old Mar 10, 2005 | 09:00 AM
Westy's Avatar
Westy
Default Correct spark gap...!
Just enquiring to see what the correct gap for the plugs in a S2 is
Car runs 18psi
Old Mar 10, 2005 | 09:08 AM
Nik_W's Avatar
Nik_W
try 0.6mm - 0.7mm
Old Mar 10, 2005 | 09:14 AM
Jim Galbally's Avatar
Jim Galbally
as big as you can get it without misfires
Old Mar 10, 2005 | 09:18 AM
Westy's Avatar
Westy
not sure about this trial and error business
Anyone else running 18psi, that knows
Old Mar 10, 2005 | 09:20 AM
Nik_W's Avatar
Nik_W
well try 0.7mm and if it runs ok with no misfire then there should be no need to worry.
Old Mar 10, 2005 | 10:01 AM
Oranoco's Avatar
Oranoco
0.8mm as standard. That's how mine are run on 25psi. Might be worth changing the heat range of the plugs though.
Old Mar 10, 2005 | 10:08 AM
Westy's Avatar
Westy
cheers
What plugs do you run?
Will set at 0.8mm I reckon Running these NGK's (were only 12 quid) Put them in, as thats what come out... SCS rebuild, He supplied plugs Hope they are OK, just seem cheap.. and cheap is not always good
Old Mar 10, 2005 | 10:09 AM
Jim Galbally
thats still not cheap for a set of plugs :P most cars are about 30p each
your normal bosch type jobbies should be fine, nout wrong with them!
Old Mar 10, 2005 | 10:29 AM
Oranoco's Avatar
Oranoco
Mine are Champion C57 C's I think. Would have to check with Rob though as I can't 100% be sure.
Old Mar 10, 2005 | 10:42 AM
Westy's Avatar
Westy
cheers
will stick to the NGK's as didnt have no probs before
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
deathrider666
Sep 28, 2015 06:12 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
