Bmw E90 DPF problems, removal?
Old Dec 16, 2012 | 05:54 PM
Nick.W's Avatar
Nick.W
Default Bmw E90 DPF problems, removal?
Evening guys.
I've seen a few posts on here about DPF removal but whilst looking now through the search function I can't find anything definitive so apologies if my questions have been asked before.
I've got a 2005 E90 330d M Sport that has developed a fault with the particulate filter and now since this morning it's bringing up a yellow warning after around 15 minutes of driving.
I've tried a good burst down the motor way but the warning comes up before any re generation can happen.
I like the idea of removing the dpf and re coding the software to suit.
My questions are: will it fail an mot with a dpf straight through replacement?
Is it a straight forward process to do the above?
Is there anything else I should know?
Obviously not going to pay £1800 for a new filter!
Cheers guys!
Old Dec 16, 2012 | 08:13 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
Buy a DPF bypass pipe off eBay an have it mapped out.
Not an mot failure either.
Old Dec 16, 2012 | 08:42 PM
c20tbo's Avatar
c20tbo
Im sure i read a thread somewhere (i own a touareg 3.0) and the guy removed the dpf and gave it a good flushing with diff solvents.
Old Dec 16, 2012 | 11:33 PM
Will Pedley Racing's Avatar
Will Pedley Racing
willpedleyracing.co.uk
Nick,
Fancy that road trip up?
Old Dec 16, 2012 | 11:40 PM
Fil's Avatar
Fil
ELASTIC BAND
I removed mine to clean out, tried solvents and pressure washing it still didn't help.
Ended up smashing the guys out and having the dpf parts deleted from the ecus software
Have passed two mots since.
Old Dec 17, 2012 | 05:57 AM
Nick.W's Avatar
Nick.W
Originally Posted by Will Pedley Racing
Nick,
I'll give you a call today mate
Old Dec 17, 2012 | 06:56 AM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
MOT wont be a problem. Far cheaper to get rid of it and have the coding removed from the ecu than it is to have a new DPF.
Old Dec 17, 2012 | 07:10 AM
JamesH's Avatar
JamesH
Worth considering if it will pass the MOT smoke test without one. It probably will, but worth being aware of
Old Dec 17, 2012 | 07:55 AM
I thought if it was fitted from the factory it had to have it on the car for a mot.I know this rule is for cats.
Old Dec 17, 2012 | 09:29 AM
JamesH's Avatar
JamesH
Yeah but if you just remove it, bash the brick out, it won't look any different
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
RSBryden
Sep 6, 2015 08:39 PM
hopper350
Sep 4, 2015 12:53 AM
Aug 29, 2015 08:16 PM
