oil breather question
will an escort oil breather be ok on a fiesta rs turbo? as from the pictures iv seen of the two they look different to eachother as i have an escort one on my fiesta engine.
also have i got it set up right on my fiesta rst engine,the breather has 4outlets 3 at the top of the breather and 1 at the bottom. iv got both my crank case outlets goin to the top of the breathe and a little filter on the 3rd outlet on the breather and the botton going to the block is that ok?
Returning below oil level stops the return line seeing any crank case presure, so the oil CAN return all the time.
In some cases if the return is above oil level it will act as a breather, and this can stop oil from returning to the sump as you have crank case pressure venting through the return line.
Just thinking on the lines of physics, how can a fluid return to a area if the area its meant to be dumping into is already full? Is it basically pressure that kind of, for want of a better word, sucks the oil away from the pipe?
I'm just imagining a bucket of water with a hose stuck in. If the hose is under water level and you fill the hose up, it will just back up the hose rather than fill the bucket.
Cheers Pete
In some cases if the return is above oil level it will act as a breather, and this can stop oil from returning to the sump as you have crank case pressure venting through the return line.[/quote]
I do not know why you say it will not fill the cranck case presure if it is belowe the oils level. ????
imagen holding a hose pipe to your mouth, and pouring water down it, the water will flow down the pipe into your mouth.
Now try the same but this time blow down the pipe. No water will reach your mouth,
Same scenario really, the return line is trying to let oil down it, it cant if there is crank case pressure blowing up it.
Yeah i understand that bit mate.
Its just below level, didn't think a fluid would empty a pipe based on gravity if below level. I had visions of it backing up the pipe lol
It's moisture, can be quite normal as oil will absorb moisture and as the oil temperature increases this will end up in the breather and mix with oil vapours and traces to cause this gunk, as well as just plain condensation.
I found moving my breather tank to the turbo side helped cure this as the actual breather tank got quite hot and it must have steamed the moisture out of the atmospheric port
If you start your car and get it warm, then take the tank off it will be very wet inside.
good read lol but is there an answer to my question... will an escort rst oil breather be ok on a fiesta rst engine (efi) as the fiesta breather has a vacume pipe on them from what iv seen. cheers rob
andrewmctiernan
08-09-2015 03:05 PM
