Megasquirt, megajolt, Where from??
Im currently on the hunt for a new ecu for my st170 engine, just a bit confused as to the differences between megasquirt ans jolt? also anyone ever used triggerwheels.com? seems very cheap as just found this
http://trigger-wheels.com/store/contents/en-uk/d31.html
Dont really want to spend loads on an ecu as its just a na car so features like boost control, alc etc are not needed
Any help would be great, trying to budget around the 300quid amrk which I know seems to be a tall order
just to add, microsquirt is another make which im unfamiliar with but is very close to my price rage for the full zetec/duratec kit from trigger wheels
megajolt is ignition only, megasquirt is what you need
eta: Microsquirt seems to be a lower spec'ed megasquirt. Depending on the injectors you're using it may just have enough outputs to work
Cheers sean
already had a look at yours an although it is very well prices and packed full of features I think its just a step too far for rfeddy and would prbably be wasted on me, at that price though someone is going to get themselves a bargain.
(your crazy for breaking the car though, always loved it )
Bear I will have a gander tomoz at boost junkey, thanks for the heads up.
I could do with doing a comparison and have a chat to rick at unicorn to see which would be best for me, although one might be a lot less equiped, if its cheaper and has the features I require then happy days, but I think I better leave that decision to may mapper, just trying to learn as much for myself as poss.
Cheers guys
Raj
Cheers guys
Raj
Cossie Sean
23-02-2006 07:26 AM
Garage19
25
21-10-2004 10:02 PM
shed
09-07-2004 03:08 PM
