Cam Buckets removed 7 but No 8 refuses to move
Old 18-11-2012 | 11:07 PM
oli49521's Avatar
oli49521
Default Cam Buckets removed 7 but No 8 refuses to move
Hi all removed the head today from a tddi focus after a cambelt failure, found 1 evident bent valve being No1 exhaust but also markings on No4 piston showing valve contact but no apparent damage to valve. So anyway i removed all the buckets and shims before i lost them in the sequence they should be in but got to the last one on No 4 cyl (exhaust) and it don't want to move it will spin round and will lift up and down but it will not free it'self from the head i've even had the bucket held with mulgrips taking the weight of the head and a mallet beating the head to try and free it but to no avail next step is to compress the valve and cut the head off and see if i can free it from the cylinder side up unless anybody can suggest anything else ?
Old 18-11-2012 | 11:41 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
The valve train componants on that port must be bent such that they are touching the side of the bucket just enough to stop it being pulled out fully.
Old 18-11-2012 | 11:45 PM
oli49521's Avatar
oli49521
so if i cut the valve head off i should be able to free it from the top of the head ?
Old 18-11-2012 | 11:53 PM
Psycho Warren
Carbon Crazy
in theory but that would be a last resort IMO.
Old 18-11-2012 | 11:57 PM
oli49521's Avatar
oli49521
what other resorts do you suggest ? the valve is operating as it should with the bucket i just can't free the bucket from the head
BRAMMER
15
14-09-2015 08:52 PM
Chopshop85
12-09-2015 06:42 PM
grishenko45
09-09-2015 12:58 PM
andrewmctiernan
08-09-2015 03:05 PM
rog
04-09-2015 07:24 AM
Quick Reply: Cam Buckets removed 7 but No 8 refuses to move
