Running greys with standard engine?
Old Mar 9, 2005 | 05:48 AM
  #41
cossy abuser's Avatar
cossy abuser
Escort one runs in the tank doesn't it so you need to upgrade even if going to 330BHP I have heard
Old Mar 9, 2005 | 07:03 AM
  #42
Spiky's Avatar
Spiky
Originally Posted by B11GNS
Originally Posted by Spiky
Originally Posted by the strut brace
ive heard that the std pump is good for about 450bhp, true???
i doubt that very much
i run 2 (only 1 used at a time) 044 grp a pumps
yeah but isn't the stansard sierra pump supposed to be a lot better then the escort one?
it is yeah, is fine in most applications when running greens, but not greys
Old Mar 9, 2005 | 12:17 PM
  #43
pugo's Avatar
pugo
i dont think that is right a standard pump in good condition will flow about 3.9 litres a minute and grey injectors will only flow about 2 litres a minute so why do you need a bigger pump??
so if your correct.you could run 750cc injectors flat out on a std 2wd pump
i don't think so
a cossie pump will probably move that amount of fluid off of the car(if its new and you get the amps to it), however, you have a fuel filter, frictional loses down the lines etc all to reduce its volumetric efficiancy
your car, your engine, your risk......for a couple of hundred quid, i would rather know my engine is getting all the fuel she wants
Pugo
Old Mar 9, 2005 | 12:25 PM
  #44
Stu @ M Developments's Avatar
PassionFords Creator
Flow data for Std pump:
PRESSURE (BAR) / FLOW (LTR/MIN) / AMPS
1 / 3.3 / 4.6
2 / 3.2 / 5.1
3 / 3 / 5.8
4 / 2.8 / 6.5
5 / 2.6 / 7
6 / 2.4 / 8
7 / 2.2 / 8.5
8 / 2 / 9.8
9.5 / 0 /11
Old Mar 9, 2005 | 12:30 PM
  #45
Same for the 044:
1 / 4.8 / 10.5
2 / 4.6 / 10.8
3 / 4.4 / 11.2
4 / 4.2 / 11.5
5 / 3.75 / 12.5
6 / 3.5 / 13.5
7 / 3.25 / 14
8 / 3 / 16
11.2 / 0 / 18
Could do serious BHP with a nasp motor
Old Mar 9, 2005 | 12:42 PM
  #46
Ginge !'s Avatar
Ginge !
just finding my feet
so stu for the not so educated, does that mean ya need a group A or not for greys
Old Mar 9, 2005 | 12:49 PM
  #47
3drstretch's Avatar
3drstretch
For that kind of conversion i woiuld also uprate the wiring to the fuel pump.As why spend all that money and let over 10 yr old wiring ruin it.
Old Mar 9, 2005 | 01:39 PM
  #48
pugo's Avatar
pugo
@stu. I have wanted those figures for ages
also FAO STU@MSD..........what pressure would you expect to see at the rail @6500rpm on greys@80%???????????????
so Stu for the not so educated, does that mean ya need a group A or not for greys
in a nut shell...........YES
Pugo
Old Mar 9, 2005 | 01:49 PM
  #49
R4N SS's Avatar
R4N SS
what about for blues as thats what i got and i think it is a std pump - car is 400bhp
Old Mar 9, 2005 | 01:52 PM
  #50
Originally Posted by pugo
also FAO Stu@MSD..........what pressure would you expect to see at the rail @6500rpm on greys@80%???????????????
Pressure?
Depends on teh boost obviously
Add boost to fuel pressure static and theres your answer.
Old Mar 9, 2005 | 02:05 PM
  #51
wimwerf's Avatar
wimwerf
but do you need a group a pump with 400bhp or not......
Old Mar 9, 2005 | 02:09 PM
  #52
Spiky's Avatar
Spiky
400bhp needs blue or greys
i would say YES you do
Old Mar 9, 2005 | 03:11 PM
  #53
The Gravedigger's Avatar
The Gravedigger
Originally Posted by rsnissan
i am thinking of going this route too and the head is suposed to have had some work done previously. just a bit worried as my engine has done 70k.
Like that's a lot
Old Mar 9, 2005 | 05:54 PM
  #54
the strut brace's Avatar
the strut brace
to sum it up, the escorts pump needs uprating without question at about 330bhp,
at what point does the saffy pump need uprating??? will i be alright , there seems to be some cofusion between wether or not 400bhp is achievable with a saffy pump
Old Mar 9, 2005 | 06:08 PM
  #55
ImaRacing 700's Avatar
ImaRacing 700
The Strut Brace...the 2wd pump is not suitable for the turbo you will be using....it needs changing from 350bhp (you can get around 385bhp but its not a good idea unless its brand new) to the 044.
Old Mar 9, 2005 | 06:26 PM
  #56
cossy abuser
One of our track cars at 380ish BHP is on a standard fuel pump, the other one is on a 044 I think
Old Mar 9, 2005 | 06:59 PM
  #57
Dave Henshall's Avatar
Dave Henshall
ok so the fuelling and the boost is not a problem, a good live map setup and away u go, what about the poor clutch and gearbox
Old Mar 9, 2005 | 07:01 PM
  #58
cossy abuser
live map
I'm running off the shelf chips
Old Mar 9, 2005 | 07:37 PM
  #59
cosworthbg's Avatar
cosworthbg
1 / 3.3 / 4.6
2 / 3.2 / 5.1
3 / 3 / 5.8
4 / 2.8 / 6.5
5 / 2.6 / 7
6 / 2.4 / 8
7 / 2.2 / 8.5
8 / 2 / 9.8
9.5 / 0 /11
Is the standart saphir pump a 909 bosch pump???
Old Mar 9, 2005 | 11:10 PM
  #60
the strut brace
is the 2wd pump the same as a 4wd pump? i'm talkin about saffs by the way, if not what is a 4wd saff rated to?
Old Mar 10, 2005 | 07:37 AM
  #61
ImaRacing 700
The 4x4 uses the same pump.
Old Mar 10, 2005 | 08:50 AM
  #62
tracktoy's Avatar
tracktoy
why run a std pump to its limit,
better to get a new 044 and know you have a safety margin, imo
Old Mar 10, 2005 | 12:12 PM
  #63
Matt's Avatar
Matt
never underestimate the stupidity of some people though stretch
new 044 pump with new wiring too imo
Old Mar 10, 2005 | 04:37 PM
  #64
the strut brace
okey dokey
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
track.focus'd
Aug 12, 2015 05:53 PM
