Osram Nightbreaker Plus or Philips Xtreme Vision? Or other bulbs?
#41
Carbon Crazy
HID's without washers and levelling will soon result in MoT failure. previously it wasnt a specific point on the test but the revisions theyve bought in this year make it a specific point that HID's must have working wash and self levelling.
The changes to the MoT are currently advisories but will come into force fully once VOSA has sorted out thier legal shit.
It was supposed to be failable earlier this year but it was delayed.
same with airbag lights being a failure, missing airbag and a few other wildcards that might catch out the modified car driver.
#42
Well, far as I know, my car has self levelling headlights, and I know it definitely has working washer jets. So we'll see if it passes. If it doesn't, it takes less than 5 mins to swap out the HID bulbs to the regular halogen bulbs, so either way, it's not really an issue
#43
Carbon Crazy
from Mot Manual:
Vehicles equipped with High Intensity Discharge (HID) or LED dipped beam headlamps may be fitted with headlamp washers and a suspension or headlamp self levelling system. Where such systems are fitted, they must work; however, it is accepted that it may not be possible to readily determine the functioning of self levelling systems. In such cases, the benefit of the doubt must be given. Headlamp washers may work in conjunction with the windscreen washers (when the dipped beam headlamps are switched on) or by a separate switch.
#44
Not entirely sane
from Mot Manual:
Lovely new rule which is completely pointless.
#46
Mine are a massive improvement over the stock bulbs - the on the road surface light is easily double, if not more, than before. I have been flashed a few times though, so I'm sure there is some scatter there. I find if I adjust the beam angle with the little dial inside (1>5 half steps), and have it on 1 or 1.5 instead of 0, then I don't get flashed as often. I've never been flashed with it on 2, but it does cut the distance projection down a bit going to 2 and above.
#50
just while were on the hid thing, has anyone tried the bulbs that are designed for reflector lights?
h7r's instead of h7's
I'm getting a set for my van, apparently they help focus the beam. I'm hoping they work as i'd rather have hid's and not blind others, than be stuck with normal bulbs.
just to update this, i got some h7r's for my astra van, and they worked spot on, all you have to do is rotate the bulb to the correct position and it will match the beam pattern of the standard bulb with no light scatter.
so they might be an option for other non projector lights
Steve Escos
01-10-2015 06:57 AM
Sierrasideways
15
31-08-2015 10:10 AM
