Dripping sump plug
Old Oct 28, 2012 | 05:01 PM
Mark_'s Avatar
Mark_
Default Dripping sump plug
Is there anything I can use to stop it dripping?
I have replaced the washer and plug but it still drips, Is there a silicone or inequivalent
that I can apply to the thread to seal it?
Old Oct 28, 2012 | 05:10 PM
MikeyRobbo's Avatar
MikeyRobbo
PS3 - MikeyRobbo
Guessing the thread in the sumps fucked for it to be able to seep past after changing both the washer and sump plug. You sure its not leaking from the sump gasket then running to the sump plug?
Old Oct 28, 2012 | 05:37 PM
Mark_'s Avatar
Mark_
Its a new sump, The thread is fine. Its tightens up nicely but not over tight.
Its a vw golf so no gasket there. The sealant used was the genuine stuff from vw, its definitely coming from the plug.
Old Oct 28, 2012 | 05:45 PM
RSargie's Avatar
RSargie
Is the sump cracked / split around we're the plug goes? Some times they split and open up when you tighten the plug
Old Oct 28, 2012 | 06:20 PM
Mark_'s Avatar
Mark_
No, I have checked it for cracks, none at all. Its just seeping out between the washer and sump face.
Old Oct 28, 2012 | 06:22 PM
Mark_'s Avatar
Mark_
Its been like it for a year, I am about to service the car and dont really want to fill with fresh oil whilst its seeping,
It takes a month or so for the oil level to drop so its not severe but its a problem I need to sort.
Old Oct 28, 2012 | 09:36 PM
cabriolet's Avatar
cabriolet
ptfe tape plumbers use worked for me
Old Oct 28, 2012 | 09:39 PM
YBJ's Avatar
YBJ
Thinking Cosworth..
+1, as it did for me.
Old Oct 29, 2012 | 06:33 AM
Cosnada's Avatar
Cosnada
Try annealing the copper washer to soften it again. I do this if I have a fuel leak too on ford banjo unions.
Old Oct 29, 2012 | 06:00 PM
Mark_'s Avatar
Mark_
Cheers guys, Ill give it a go, Just waiting for the service parts to turn up now.
I was going to try a thread lock but ptfe sounds good
Old Oct 29, 2012 | 06:07 PM
STeve's Avatar
Super Moderator
PTFE is the invention of the gods as I have lost count of hows many times that stuff saved the day
Old Oct 29, 2012 | 06:14 PM
phil_focus's Avatar
phil_focus
check if the sealing face of the sump is flat.
Old Oct 30, 2012 | 09:16 AM
gingeRS's Avatar
gingeRS
if its 'definitely' the plug then either the sealing face isn't flat or the threads are baggy.
Old Oct 30, 2012 | 05:36 PM
Mark_'s Avatar
Mark_
The face is flat, i used a little bit of thread lock and it seems to have solved the issue.
Would have used some PTFE tape but I couldn't find the role I have.
Old Oct 30, 2012 | 05:44 PM
saph4be's Avatar
saph4be
Can't beat some ptfe tape floating around your oil pump clogging up oil ways!
Old Oct 30, 2012 | 10:02 PM
TrevCos's Avatar
TrevCos
I always put a bit of gasket seal on the sump plug washer, always worked for me.
Old Oct 30, 2012 | 10:15 PM
botters's Avatar
botters
competant bodger
if its a golf then new sump or not it will have fucked threads in the sump lol, the amount of these ive helicoiled!
Old Oct 31, 2012 | 08:51 AM
Brendan's Avatar
Brendan
struggling with reality
Citroen sell hollow copper washers to stop this happening the deform to exactly fit the gap between sump and plug. Thes work well
Old Oct 31, 2012 | 05:01 PM
Mark_'s Avatar
Mark_
Thread isn't fucked on this one, It tightens up like any normal thread, The old one that was on there was fucked though,
Old Oct 31, 2012 | 05:02 PM
Mark_'s Avatar
Mark_
Will look into these, Sound great
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
Iain Mac
Sep 30, 2015 09:39 PM
deathrider666
Sep 28, 2015 06:12 PM
youngben
Sep 27, 2015 09:37 PM
