Escort Td engine
Old Aug 25, 2012 | 11:12 AM
p100rallyesport's Avatar
p100rallyesport
Default Escort Td engine
Dors anyone know anything about these engines? It's a endura de p e in a 2001 escort van???
Thanks in advance, Shanti
Old Aug 25, 2012 | 07:36 PM
cabriolet's Avatar
cabriolet
err know loads but what in particular u after
Old Aug 25, 2012 | 07:40 PM
p100rallyesport
I got this one in the pic below can I put a intercooler onto
It or not and if so what does it involve and will I get any benifit from doing so
Old Aug 25, 2012 | 07:46 PM
flannigan's Avatar
flannigan
No that's a 75bhp model the intercooled version was 90bhp I am sure the fuel pump and turbo is different on the two models
Old Aug 25, 2012 | 07:54 PM
cabriolet's Avatar
cabriolet
as said above u need different pump different wiring intercooler brackets and pipework easier to buy a intercooled scrapper and change it all
Old Aug 25, 2012 | 08:08 PM
p100rallyesport
Ok could I drop a intercooled lump in out of a escort complete but use my existing wiring loom or do I have to use the loom out of a intercooled one??? And will the loom Un plug and plug back in under the bonnet??
Thanks guys
Shanti
Old Aug 25, 2012 | 09:48 PM
vaughant's Avatar
vaughant
The intercooler is only there to allow you to run more boost safely so in theory you can put any intercooler on and just up the boost a bit although those engines are so strong you can just run a bit more boost safely enough on it without the cooler.
Old Aug 25, 2012 | 10:09 PM
botters's Avatar
botters
competant bodger
i can only ask why? you will literally be throwing money away mate these engines are lethargic regardless of what you do to them just leave it as is and enjoy the great mpg lol
Old Aug 25, 2012 | 10:59 PM
p100rallyesport
Just curious to be honest
Tha is for the info guys
Old Aug 26, 2012 | 08:00 AM
zippyobrien's Avatar
zippyobrien
They go well when tuned. Seen a couple of 140 bhp ones.
Kent even do a cam.
Old Aug 26, 2012 | 09:29 AM
p100rallyesport
Kent even do a cam.
Oh ok which engine is that for the intercooled one from the escort?
Old Aug 26, 2012 | 03:58 PM
zippyobrien
There all the same ( dimensionally and iterchangability ) across the whole 1.8 range.
Old Aug 26, 2012 | 04:17 PM
p100rallyesport
Oh so I can use the one I have or not?
Old Aug 27, 2012 | 09:09 PM
bortaf's Avatar
bortaf
You can fit an intercooler yes but it wont be as good as the 90 version as they have more fueling and boost to go with the IC.
Internaly all the 1.8s are the same, i have an escort non turbo block and head in my sierra TD it's just the bolt on bits that differ
Old Aug 28, 2012 | 12:06 AM
p100rallyesport
Right ok then thanks but not really worth doing then is it might as well stick the 90 HP lump in
Vincereese
Jun 1, 2023 09:14 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
muz
Aug 16, 2015 12:57 PM
Old ford
Jul 31, 2015 06:50 AM
