What should I do next with my saph?
Well I have finally managed to get all the bits for my ideal spec, perhaps not the choice of everyone but it what I've always wanted.
Anyway, I now have all the bits ready to fit when I return to the UK next week, but I'm still trying to figure out what to do with the front diff and driveshaft arrangement tbh.
Car is all rebuilt and running a T4 and siemens 83's, will be swapping the box out for an straight cut Oppliger box fitted and rebuilt diffs front/back, plan after that is to get it down to Tony for a proper map. But to use it in anger I have always had problems with the front shafts breaking, so I'd like to fit something else and change the diffs for something better, and bigger ideally, starting with the front.
What options do I have??? I don't want to go fitting different diffs to the same casing if I can avoid it. Lots of work to do on the car, but now I finally have al the bits!![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
Car is pretty well specce'd so apart from the lag it doesn't want for much else really, but i was thinking about cams...
Rebuilt diffs by GEARS
Oppliger straight cut box
Fully rebuilt lightened and balanced engine, standard comp.
RS 500 T4
Siemens blacks
MSD fan loom
MSD Fuel pump loom
044 fuel pump
Full Aeroquip everywhere
Konis with eibach springs
AP brakes
RL7 wheels
All spec R tanks everywhere
Samco everywhere
All Stack gauges apart from dash
SECS monitor
RS 500 T4
Siemens blacks
MSD fan loom
MSD Fuel pump loom
044 fuel pump
AP brakes
RL7 wheels
Samco everywhere
SECS monitor
are the shafts breaking or pulling out of the diff? if they are pulling out xr4x4 shafts are longer but some people have had vibration problems. iirc ggr sell uprated shafts.
Six degree rear beam!
Front Diff with a nice steel sandwich plate should survive ok, if it does break then they are about 50p each anyway!![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Rear diff just go 2wd 7.5" as it's only getting 66% of the power anyway, and the ratios are near enough the same so it will work fine, and give you 108mm cv joints as well on the back.
It Wasnt Me!
are you determined that is has to stay 4wd? to my mind it would be much more cost effective to go 2wd, instead of possibly buying/breaking/fixing expensive 4x4 parts.
Could do something different and go 6 speed 2wd
Deffo staying 4x4 mate, I have been hassled to death about making it RWD and stuck to my guns, for now it will remain GWD![gayfight](https://passionford.com/forum/images/smilies/gayfight.gif)
I suppose I should see what breaks next then go don that route!
Keep hankering after something else to go on track with and I'm not sure if this saph is the answer.
Well time will tell, too late now as I've paid for the box ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
TBH if anything it's a good opportunity for other folks on here, I will give other people a good run down on Oppliger and how the box performs as there doesn't seem to be much feedback on it.
I wouldn't track that rog,it's far too nice a car and if you bumped it you'd be gutted,not 100% but would the t4 be a bit laggy for track use?im no expert though.
Loads of fun track beasts out there you an tow easier as well,I'd say you'll have as much fun in a 2.0zetec ka etc and not really care if you wipe it out compared to the cossie where you'll be thinking "shit if I bin this or something pops its gonna ruin my day".
Just a thought.
Maybe a pm coming your way regarding the compEX course,doing survival Monday and would be interested to know a few more details about compex before I commit.
Just a thought.
No worries, I have a friend that is a training administrator at a local company that specailise in compex, so I should be able to get you all the info you need.![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
I'm with you on the track/condition dilema, I've never seen a really nice saph on track before, but that's kind of the idea behind it lol. But havig owned it for almost 12 years I'd be pretty gutted if I binned it.
Home next tuesday, need to remove the 800 gearboxes and other bits from the garage and I'll get the car pulled out to get the electrical issue sorted out once and for all! Plus I have all my stack stuff to wire in before I put the dash back.
Nae worries rog,give us a bell when your ready fella.
Would look super cool to see a saph being used in anger on a track day but it would be heartbreaking to spoil that one.
Leave it 4wd, put a 6 degree beam, get a geometry set up to make sure all the suspension is perfect for your needs, and enjoy.
Although, you could run anti lag.......
Home next tuesday, need to remove the 800 gearboxes and other bits from the garage and I'll get the car pulled out to get the electrical issue sorted out once and for all! Plus I have all my stack stuff to wire in before I put the dash back.![Big Grin](https://passionford.com/forum/images/smilies/icon_biggrin.gif)
I would enjoy the old girl, least you can lol
If you need a hand with tidying up ect, give me a shout, im home this monday, as long as the kettle is on.
Personally I wouldn't track this car, maybe at the rs show at knockhill, that's the only time mines went on track because there's other rs owners on the track and it's not full of novas or subarus with talentless drivers but on the other hand that car with that spec will be an awesome thing on track
1. Nitrous
2. Anti lag
3. Carbon body panels
2. Anti lag
It Wasnt Me!
I've got a feeling once you fit the box and get it out, you're going to fall out with the car as it'll be a (and don't take this the wrong way) harsh, noisey, laggy thing to drive...IME when people go mental with modifying their motors, it slowly becomes something they don't enjoy, my suggestion about going 2wd was moreso for the fact that you can have the power but keep a standard T5 'box, so the car remains nice to drive!
Russ Payne
25-09-2015 08:29 PM
