oil filler cap on erst
sounds like blocked breather pipes buddy cdisconnect and clean them out and it should cure it. i'm sure if i'm wrong some1 will say so
yeh its only just done it today,havnt used the car for a couple of
days and it was fine the last time i used it,i topped the oil up
a little the other day and put a tiny bit to much in so would this cause
the same thing to happen
www.ctuceilings.co.uk
Originally Posted by jonesymk2
how much do after market breather systems cost anyway
#1 in Spelling Club
Note - You can't use a Breather that vents to atmosphere on anything other than a very new engine.
had thoght about a bit of tape round the filler neck to make it a tighter fit
does it vent to atmosphere instead of where,mine wont tickover if
the caps off so how would i sort that
so if i just block the pipe off on the metering head and also block the
pipe on the inlet manifold and just then vent the pipe from the rocker
cover to atmosphere,then just turn the revs up a little and is that it
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
03-11-2015 04:08 PM
