Custom Boost/ Intake Pipe
Old Aug 11, 2012 | 06:12 PM
surrey_100e's Avatar
surrey_100e
Default Custom Boost/ Intake Pipe
Hi guys,
I need to fabricate a custom shape pipe from my intercooler to the inlet.
I was thinking about making it out of aluminium pipe that would have to be cut into lots of different angles and welded together, the other option i was thinking is, is it possible to make boost pipes from carbon fibre? I could mock a template up using something the right diameter such as card tube and then either buy a kit or find someone that could turn it into a carbon fibre item?
Will it hold the pressure?
Another thing, does the map sensor have to go in the inlet pipe or can it be remote mounted?
Martin
Old Aug 11, 2012 | 06:20 PM
crazycage's Avatar
crazycage
Originally Posted by surrey_100e
Hi guys,
Martin
the map sensor wants to be in the inlet plenum not the boost pipe. i would use 90 degree elbows for the boost pipe and cut them back to any angle you want .
Old Aug 11, 2012 | 07:23 PM
GARETH T's Avatar
GARETH T
How complex is the shape? Can't find a silicon hose the correct shape?
I don't like these ally boost pipes, as I think you are doubling the number of joints for possible leaks!
Old Aug 11, 2012 | 07:24 PM
GARETH T's Avatar
GARETH T
And as said, the map sensor needs to be after the throttle plate!
Old Aug 11, 2012 | 07:25 PM
gus's Avatar
gus
how long are pipe runs
as if too long silicone will collapse
wowk
Mar 30, 2021 07:49 PM
mpilk
Sep 27, 2015 09:21 AM
