how do you test a map sensor
Old Aug 10, 2012 | 07:08 AM
CHUNKYS RS's Avatar
CHUNKYS RS
Default how do you test a map sensor
as above 2 bar cosworth item
Old Aug 10, 2012 | 09:35 PM
stevieturbo's Avatar
stevieturbo
C**t
Apply vacuum or pressure as required and measure the output voltage. Same as any map sensor.
Old Aug 10, 2012 | 10:23 PM
daz1968's Avatar
daz1968
I tried but found it much easier to fit a known working one to help identify problem, over the years I have collected all sensors in known working condition, I find it the easiest way, not difficult to find a good 2 bar sensor used and far less hassle than monitoring outputs.
Old Aug 11, 2012 | 08:19 AM
Brendan's Avatar
Brendan
struggling with reality
resistance meter and a pump!
Old Aug 11, 2012 | 09:21 AM
grcossie's Avatar
grcossie
Here you go
http://www.cannell.co.uk/Ford_Worksh...sis%20Info.pdf
Old Aug 11, 2012 | 01:53 PM
CHUNKYS RS's Avatar
CHUNKYS RS
thank for the link grcossie very helpful
Old Aug 11, 2012 | 06:02 PM
grcossie's Avatar
grcossie
Nice to help, i always use this for sensoe check on Cosworth`s even that we Ford`s one at work
Old Aug 11, 2012 | 06:38 PM
GARETH T's Avatar
GARETH T
I got test leads, with male and female timer plugs on either end and test points (4mm banana sockets) mounted in a box.
Old Aug 11, 2012 | 07:25 PM
grcossie's Avatar
grcossie
We have an y-cable and a breakout box, whit test points at work. Y-cable is for Cosworths and breakoutbox is for many cars
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
jay030787
Sep 25, 2015 01:38 AM
