RS 500 INTERCOOLERS
RS 500 INTERCOOLERS
Im going to buy 1 next week but there are so many on the market made buy different companys, where should i get 1 at a good price as i dont want to spend loads if i can get 1 just as good cheaper??
or het a real rs500 jobbie,550 quid i paid for mine,i KNOW its apparently not as good as that thing above but at least it aint a gay silver thing and was plenty good enough for my 400 bhp saff!
Originally Posted by big_wig_074
BBBBBBBBBEEEEEEEEEEEEEEHHHHHHHHHHHHHHHHHHHRRRRRRRR RRRRRRRR!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
590 BHP/Ton
Originally Posted by ECOSNIGE
Are the pro alloy rads the same as what pace use just different end caps??
Pace use a three row core with 1/2" wide tubes side by side, giving a cross sectional Flow area of 38.1 mm.
Our cores have two rows of 22mm tubes side by side giving a cross sectional flow area of 44mm... this might not sound like much but when you consider that there are 30 rows in height the total cross sectional flow area is 177mm more with this design.
our cores are also made from a magnesium alloy..This actually makes the fins far stronger and makes the construction generally stronger- ideal for motorsport or track days where there are higher demands on both cooling and structural integrity.
590 BHP/Ton
Yes although, not quite the same shape as it used to be!!! But it's not leaking!!!
590 BHP/Ton
Originally Posted by Dean Saff
How much are the pro rad fans do they fit the same as standard fans
They do fit to the standard and most alloy rads.
