spigot bearing how do you remove them
any one no were i could get a bearing that goes on the end of the crank were the gear box mates up it sit in the end off the crank it think its called a spigot bearing how do they come out any one now
Team HOTHOT!
fill the hole with grease, get a piece of metal bar thats a perfect fit into the spigot bearing, and tap it with a hammer - the grease will push the bearing out
Re: spigot bearing how do you remove them
You can buy a Spigot puller, but the grease trick usually works ok (so long as its heavy grease) You can use a blocked up socket on an extension bar for the "drift"
i have a new t34 turbo 2 weeks old from new also engine is fully rebuilt but iam gettin oil from around the turbo joint were the exshust back housing bolts up to the center houseing and when its left idaling for about 10 min you can see the oil burning off the turbo but the turbo doesnt smoke out the back at all
