Tips on 1/4mile racing
Tomorrow I'm off to a local abandoned airstrip as the is a drag racing event for any cars..
Basically can anyone give me some tips on launching etc or not launching, 2nd gear launching or anything that will help me!
I have launch control on my omex ecu but havnt had it mapped in yet
Thanks, Joe
Thanks, Joe
lets some air out of the tyres for a bigger foot print, take any uneeded weight out of it, and practice, pratice, practice. What car do you have? rear wheel drive? 4 wheel drive? Front wheel drive?
What car do you have? fwd/rwd/4wd? what power/weight?
I wouldn't use 2nd gear, you could possibly kill your clutch or gearbox.
If you get to the start line 1st it can give you a few extra seconds to compose yourself, rather than rush if you're 2nd.
Reaction times don't add to your 1/4m time so go when you're ready, don't rush and end up wasting a run.
try shallow staging.
http://www.modernracer.com/tips/dragracingbasics.html
Sorry it's a series 2 escort, Not sure on power because I'm still on my running in map so I'm only running 6psi or so..I've got a 4 paddle clutch if it's helps, I want to see my times on this map then it's on agai next month so I'll get back up to Norris Motorsport for a proper map and hopefully run around 280bhp ish.
Thanks, Joe
Thanks, Joe
u wont have enough power for 2nd gear launch and probly do the box and clutch, just do sum runs and see how it feels every car is different , put semi slicks on it and start with 15psi and go down to 10 or 8 and see what difference it makes , find the bit hold it on the handbrake at 4k ish and then go for it
2nd gear burn out helps if u can get it goin lol
The Youth.
30-09-2015 09:59 PM
Si B
12-09-2015 06:49 AM
