Another failed gated sump causing engine meltdown
Old Aug 1, 2012 | 12:41 PM
  #81
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Originally Posted by dojj
the rainbird has probbaly bloced chip until he has proof
or maybe he was searching for it all along before he made such a bold statement
I've PM'd Phil the link already, I just didn't want to ruin this thread with irrelevance .
Old Aug 1, 2012 | 12:52 PM
  #82
Ima Racing's Avatar
Ima Racing
That was very relevent Mike, its a monumental day, i was having a really bad day until i read the link PM'd
Old Aug 1, 2012 | 01:21 PM
  #83
dojj's Avatar
dojj
Resident Wrestling Legend
if it's about them adjustable top mounts, i think i remember the thread
but back to the question at hand, far be it for me to sound like i'm kicking someone when they are down, but that nut welded to the sides does look a very pikey way to do thing
i'm not familiar with gated sumps from other manufacturers but i'm assuming they use a more industry standard method of fixing than that?
Old Aug 1, 2012 | 06:02 PM
  #84
flannigan's Avatar
flannigan
Originally Posted by stevieturbo
is it a strainer or a wire fence ?
Ive never seen a strainer with mesh so coarse that something as big as that pin could ever fit through.
picture explains better
Old Aug 1, 2012 | 06:22 PM
  #85
stevieturbo's Avatar
stevieturbo
C**t
It explains how it got in, but how on earth did that hole get created in the mesh ? It's not like there's a ninja turtle in there bashing it's way through
Old Aug 1, 2012 | 06:26 PM
  #86
Moonstone Steve.'s Avatar
Moonstone Steve.
Originally Posted by Turbosystems
nothing wrong with that sump mike apart from the lower row of holes look a little low
No chance of the gates falling off lol
it's the ones people have made with the sides either cut out or have drilled massive holes in like moonstones steves which we shall be binning
Whatever you do do not throw anything of mine in the bin please.
Steve
Old Aug 1, 2012 | 06:30 PM
  #87
flannigan's Avatar
flannigan
all i can think is the oil pump sucked it against the strainer and the sharp edge of the broken pin wore its way through the mesh the bottom of the sump below the strainer looks like it has been shot blasted where the little fooker was bouncing off it getting a run up at the strainer mesh !!! i guess im just lucky pmsl
Old Aug 1, 2012 | 06:31 PM
  #88
flannigan's Avatar
flannigan
Steve
do you want him to cut it up first then throw it in the bin ??? lol
Old Aug 1, 2012 | 08:02 PM
  #89
Turbosystems's Avatar
Turbosystems
Super Moderator
Poor moonstone panicking he sounds like 4i now
your sump would work ok steve if it had a proper gated baffle system at the moment it is just a big empty box clearly designed to maximise oil surge
flannigin has a cheap one for sale
Old Aug 1, 2012 | 08:12 PM
  #90
Moonstone Steve.
well fit one then and stop whining about it lol
Steve
Old Aug 1, 2012 | 08:16 PM
  #91
Turbosystems
Super Moderator
Steve
It's alright you saying that but all these bits add up and then it will be you whining like a 4i about the bill
Good news though your sump plug is ok
Old Aug 1, 2012 | 08:18 PM
  #92
flannigan's Avatar
flannigan
Steve
are you sure you can afford it mate as i have heard they are Ł1000 !!! rofl
Old Aug 1, 2012 | 08:19 PM
  #93
Moonstone Steve.
All you need to do is tell me how much and i will arrange payment.....thats how it works
Steve
Old Aug 1, 2012 | 08:20 PM
  #94
Moonstone Steve.
Steve
Old Aug 1, 2012 | 08:21 PM
  #95
Turbosystems
Super Moderator
I'd sooner pay 1k for one of mine that 1 pound for one like yours
the sump is the only part of your engine that you didn't get from That Toan the fookin moan
Old Aug 1, 2012 | 08:30 PM
  #96
rsnissan's Avatar
rsnissan
Originally Posted by 750hp escos
Its actually a worse idea to have a big wing sump and no baffles than to just have a std sump!!!
My car was a road car, however I never had any problems when cornering (as fast as mechanical grip would let me in a 2WD) certainly no gates failing anyways...
This was my sump;
Old Aug 1, 2012 | 08:31 PM
  #97
flannigan's Avatar
flannigan
yes i know and look where it got me lol does this mean that because im spending more money with you i am in some way sponsoring youre car as i have a turbosystems sunstrip on mine its only fair that you have a DC autoservices one on yours lol
Old Aug 1, 2012 | 08:43 PM
  #98
750hp escos's Avatar
750hp escos
This was my sump;
In all fairness to you and mike id never seen one like that but looking at it id say its not a bad idea and like said atleast the baffles cant fall apart..!!lol
The only big wing sump iv seen is one where the sides have been cut out and the wings welded on for more capacity..
It obviuosly works as iv heard about mikes driving and im sure that would of had bottom end failure before now if it didnt work..
To your worries mike about a dry sump set up,yes i used to worry alot about gravel traps etc and belts but iv had one on my car since 2005 and never had an issue..
The belt being ripped of by anything is about as unlucky as a stone or similar going into the cambelt on a cossie with out a cover on??
Ive never known it to happen??although i did re build the pump twice in that time and change the belt about 5 times..
cheers danny
Old Aug 1, 2012 | 08:46 PM
  #99
rsnissan's Avatar
rsnissan
Cool...
You had me worried for a bit
  #100
750hp escos
Steve
Why not just go the whole hog and have a special sump baffle and breather???
One thousand of your finest please sir??lol
Fook me i could get a supra diff conversion for that!!!!
cheers danny
Old Aug 1, 2012 | 08:49 PM
  #101
750hp escos
Cool...
If you can imagine there being no side walls with the holse but big wings?
Then the oil could freely move side to side and the strainer could get dry causing issues??
But looks like a good idea in all fairness and obviously works..
On a road car id deffo just do this in the future..
cheers danny
Old Aug 1, 2012 | 08:52 PM
  #102
Moonstone Steve.
This was my sump;
From memory thats how mine looks......I was told its a pile of scrap
Steve
Old Aug 1, 2012 | 08:54 PM
  #103
Moonstone Steve.
cheers danny
How is the diff conversion? thinking of getting one myself, did you get a good deal????
Steve
  #104
rsnissan's Avatar
rsnissan
You sure the holes are the same size?
Old Aug 1, 2012 | 08:55 PM
  #105
flannigan's Avatar
flannigan
cheers danny
That's where you're wrong I'm affraid they are Ł5000 pmsl
Old Aug 1, 2012 | 08:57 PM
  #106
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Come on Moan post a pic of a proper sump then.
Lets see what i will be getting for my money
Steve
Old Aug 1, 2012 | 08:58 PM
  #107
Moonstone Steve.
They look the same, I might have some pics somewhere.
Steve
Old Aug 1, 2012 | 09:16 PM
  #108
rsnissan's Avatar
rsnissan
Bad boy Sump
Old Aug 1, 2012 | 09:24 PM
  #109
Moonstone Steve.
Thats scrap that is pmsl
Steve
Old Aug 1, 2012 | 09:28 PM
  #110
flannigan's Avatar
flannigan
What did that come off ? Where is it now ?
Old Aug 1, 2012 | 10:30 PM
  #111
BRAMMER's Avatar
BRAMMER
Now that sump is flash, who design is that?
Old Aug 1, 2012 | 10:43 PM
  #112
wes's Avatar
wes
Thats a DJR sump
Old Aug 1, 2012 | 10:51 PM
  #113
rsnissan's Avatar
rsnissan
Originally Posted by wes
Thats a DJR sump
top marks
Old Aug 1, 2012 | 11:51 PM
  #114
Tarren's Avatar
Tarren
Now thats a awesome sump !!!!!!!!!!!!!
Old Aug 2, 2012 | 03:59 AM
  #115
dojj's Avatar
dojj
As per usual, andy turns up, out of the blue it would appear, and brings out all these wonderfull pics of stuff he's got
He's like a real life batman
Old Aug 2, 2012 | 06:28 AM
  #116
marco polo's Avatar
marco polo
Hi flannigan
Sorry to see and here about your engine firstly I do feel for you and sorry this has happend
I have 2 of these sumps on my engines one which is on my 3dr has been on for about 6 yrs
The guy who makes them is a very good friend of mine I haven't spoke to Him yet but will do some point today
I'm a bit paranoid now to check the one on the 3dr the other one I have is not fitted to the escort
I feel kind of bad that yours has failed as these are ment to be for racing and suppose to be the bizz as they are an exact copy of the ford touring car only smaller in oil capacity and the next best thing to dry sump
How long have you had this sump???
Cheers Marco
Old Aug 2, 2012 | 08:47 AM
  #117
flannigan's Avatar
flannigan
I bought it in 2008 but it was only fitted in 2010 and has covered approx 3000 road miles and 7 trackdays !
Old Aug 2, 2012 | 08:52 AM
  #118
750hp escos
Steve
A better deal than your going to get with your engine!!!!lol
Infact i have found a very good way of getting a good deal thanks..
PS
If your sump is the same as mikes and andys id say you would prob never have a problem with it..might free up some cash for some proper mods on your engine??
cheers danny
Old Aug 2, 2012 | 09:47 AM
  #119
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
What would be nice to know is where is the maker of these gates and why isnt he on here explaining what he thinks went wrong?
Sorry to read your engine is destroyed
Old Aug 2, 2012 | 10:16 AM
  #120
Stu @ M Developments's Avatar
PassionFords Creator
With comments like that about a fellow trader, do you honestly wonder why Tony doesn't seem to be in a hurry to help you with anything?
