ZeroLag turbo technology.... Is this to good to be true
Was just browsing through facebook and stumbled across this someone had posted.
What's peoples thoughts about it?!
http://www.s2forum.com/forum/showthread.php?t=59647
Looks amazing!
Also, love how people comment on the video "oh tell me how it works" Yeah, he has probably worked years to program it all and you expect to just be told? Faggots.
There's a lot of info in the first link I posted with pictures of the setup.
Looking at about 20k for a working setup tho
By the sounds of it, the bloke whos Impreza its on in the video worked at Prodrive developing the WRC engines
Shamelessly copied from S2 forums:
The item you refer to is known as a "rocket". This device is fitted to the header just in front of the turbo and works as a sophisticated anti-lag system.
Air and fuel are fed into a combustion chamber and ignited by a spark on over-run, it can be used in three stages (depending on how long you want the engine to last) and is the cause of the load banging noise that can be heard as these cars pass by and the flames coming out of the tail pipe. This system is used in conjunction with the boost pack which stores excess pressure in it's own reservoir to be fed back into the engine inlet side of the inter cooler when the throttle is depressed after shut off.
All this is coupled to the "flat change" gear shift and launch control system which is of course controlled the the ECU.
Just to give you some idea of prices:
WRC Header £2,200
WRC Turbo £10,000
Boost Pack £3,000
ECU £5,000
Engine Wiring Harness £3,000
The "rocket" system was removed from customer cars by Prodrive, and only cars still under contract (S11 onwards) left the factor with this spec.
Hope this was of help
WRC Header £2,200
WRC Turbo £10,000
Boost Pack £3,000
ECU £5,000
McGarrity Motorsport
I've actually experienced a full bore launch in a S12b Impreza. Its weird to say the least, you give one rev to around 4k to build pressure. The revs then settle to around 1800rpm and the engine sounds rough and lumpy. At this point it's making 3.5 bar of boost then all the driver has to do is floor the throttle and he's away.
Ok so my idear of cutting the ing filling the manafold with unburnt fuel then firing the whole mix with a cooker igniter in the collector an boooom ! big manafold pressure = no lag ?????
or use a small jet engine to directly power a turbo, then you can run whatever boost you like at any rpm!
http://raceenginedesign.biz/Manic-Beattie.htm
