FFD Gearbox
FFD Gearbox
Is the anyone here som can tell me which one of the FFD gearbox some are good? Is the 6 speed FFD with handbreak release the best (the last generation)?
The last one could you get with handbreakerelease or active centre?
B1mbo
OP I would go for a 6speed box if going h patter as its very easy to miss gears with the 7speed and they are not cheap
Also be careful on ratios as they were designed for 4.44 diffs.
You need a wrc active mpc pump and whole kit including accumulator and all the other gubbins. The power steering works off the mpc pump.
I have a 6 speed FFD with handbreak release. I was told the pump are in the gearbox? And I need a oil tank.
Is that correct?
Jim,
There were a number of combinations with the active hanbrake release, people like Chris Mellors, pete doughty and RED ran the cars with semi active systems, these used a main valve block, accumulator and only one rexroth for the centre diff, the front diff remained passive, they ran those cars with either the 90BAR pump or sometimes an electric power steering pump, they did work ok and gave the advantage of unlocking the centre diff without all the other equipment...
FFD is a fabulous box, loads of cheapish spares still available without paying Xtrac tax....
chowfornow
14
05-01-2019 09:01 PM
