Pull up reverse?
Old Jul 9, 2012 | 03:24 PM
AshleyH9194's Avatar
AshleyH9194
Default Pull up reverse?
Hi all,
How easy is it to remove the pull up reverse? without replacing the whole selector or locking it in place. I need it so it can just put it straight in reverse.
thanks
Ash
Old Jul 9, 2012 | 03:54 PM
swain78's Avatar
swain78
On mine i just cut the tab off on bottom of shaft. Worked fine for me. On 2.0zetec with mtx box
Old Jul 9, 2012 | 03:59 PM
AshleyH9194
tab on bottom of shaft?
this is my selector
there's no tabs at the bottom or under the rubber gaiter
do you mean the actual pull up part?
Old Jul 9, 2012 | 04:12 PM
cossiestu's Avatar
cossiestu
If you remove the rest of the gear knob, you might get better access to the lift up bit. There was a thread on here recently about removing the gear knob....
Old Jul 9, 2012 | 04:31 PM
AshleyH9194
i have removed the rest of it, just an old pic from that as that was my thread so where is this tab?
Old Jul 9, 2012 | 04:35 PM
cossiestu's Avatar
cossiestu
Bugger! Sorry, I thought I recognised the picture from somewhere.... Can't remember seeing a tab or anything, but it was years since I changed my gear knob.
Old Jul 9, 2012 | 04:59 PM
AshleyH9194
ok no worries mate, just need to get rid of the darn thing
Old Jul 10, 2012 | 10:07 AM
AshleyH9194
someone must know if and how this can be done? i know the quick shift kit you can get allows you to fit a pull up reverse to a non pull up shifter so you must be able to remove it? surely?
timsrs
Nov 13, 2018 11:48 AM
tankybaby66
Feb 6, 2016 02:24 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
cameron2
Sep 20, 2015 04:30 PM
