overheating!!!
Old Jul 6, 2012 | 07:15 PM
orion turbo's Avatar
orion turbo
Default overheating!!!
i gettin pretty annoyed lately with my cars overheating problem. and what makes it wierder is the temps only rise when driving up hill. just drawn a blank.
Old Jul 6, 2012 | 07:18 PM
scoooby slayer's Avatar
scoooby slayer
my old combi van did that 12 years ago, the rad was knackered, the old mans range rover bmw 2.5 dti did it aswell and that turned out to be headgasket after sniff test. both were fine cruising but high loads would overheat.
i assume youve checked/changed the stat ?
ive had a tractor do it aswell and stat was rusted solid half open, so would run super cool then slowly get hotter and hotter under heavy load.
Old Jul 6, 2012 | 07:27 PM
orion turbo
iv a new stat to go in. was thinkin bout water pump as well to be on safe side.
Old Jul 6, 2012 | 07:28 PM
E980VTJ's Avatar
E980VTJ
is your fan kicking in,when it get's hot put the heaters on full problem solved
Old Jul 6, 2012 | 07:29 PM
orion turbo
iv got my fans on an override switch in the car. and heaters in the car dont really make a difference.
Old Jul 6, 2012 | 07:36 PM
E980VTJ's Avatar
E980VTJ
have you checked the radiator hose is getting hot.
Old Jul 6, 2012 | 07:40 PM
orion turbo
no not done that one. which hose (top or bottom)
i dont even have to be flooring it up hill even stationary on a hill it creeps up
Old Jul 6, 2012 | 07:45 PM
E980VTJ's Avatar
E980VTJ
my 07 astra van sits at around 83 but on a hill it goes to 90,is it actually over heating or is the temprature just rising.
do you have hot air out of the heaters?
Old Jul 6, 2012 | 08:04 PM
orion turbo
the needle sits on the 'N' either when driving or sat on a hill
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Ade
Feb 8, 2007 05:11 PM
kurdt5
Jul 17, 2006 03:01 PM
fiestaturbo1984
Feb 19, 2006 03:51 PM
woodz77
13
Nov 6, 2005 03:02 PM
