Ka coolant issue
Ka coolant issue
Hi everybody, a newbie to passionford here. I recently had a bizarre issue which has stumped me and was wondering if anyone else has had a similar problem. My wife and son share an 07 plate ka zetec climate, my mrs came home from work and told me the heater was only blowing cold air, upon investigation the coolant catch tank was completely empty. I filled the tank with water and coolant and ran the car for about 20 mins before checking the level finding it to be fine. The next day I took my car to a garage who pressure tested the cooling system to twice its normal pressure with no signs of a leak. The problem has not resurfaced since. The question is, where did the water go and is it likely to happen again.
Thanks in advance for any ideas.
Firstly check the cap on the water header tank, the rubber seal twist, crimp, or perrish meaning it doesnt seal.
This happened to us and a quick straighten out of the rubber 'o' ring and it solved the issue. Would never have believed it but apparently common. Also check that the fan is kicking in when it gets hot as they can pack up over time.
If the oil is all fine and not mayonaisy, and there are no water leaks from pipes int he bay, or inside the car - check the carpets for damp - could be a heater matrix?
If all of this is fine, then it may well have just been the cap letting the water evaporate.
SMILER258
28-09-2015 10:04 AM
mk1focus
Ford Fiesta
24-09-2015 07:19 PM
