Can it be a hole in flexi pipe causing my engine problem
Hi Guys,
As some of you may remember I posted a thread about my Ford focus having a issue with the running or of the engine and that there is a sudden loss of power for a second or 2 (only seems to do it after the car has been running for about 5 mins). Now i initially thought it may have been the fuel filter being blocked, still a possibility. But over the last couple of days I've been out in the car and the noise coming from the exhaust is unreal (sounds like a tank) I've been under the car and there's a small hole in the Flexi pipe at the front of the car, could this be causing my sudden power loss, cos I've been told the Lamba sensor in just forward of the exhaust flexi pipe which, correct me if I'm wrong controls the fuel flow to the engine???
I'm guessing now but if there's a hole near this particular sensor then the fuel and oxygen mixture isn't going to be right is it??
If I then replace the flexi pipe with a new one would this solve the problem, or would I have to replace the Lamba sensor aswell.
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
JoeyBoyden
Aug 18, 2015 10:52 PM
Gadget
Aug 13, 2015 08:19 PM
track.focus'd
Aug 12, 2015 05:53 PM
