Ford Focus S reg loses power and sluggish at 20mph in 2nd Gear, 30mph in 3rd
Hi guys,
I'm going to try and explain this problem as best I can, I know nothing about cars so don't know the terminology so please bare with me. Just recently when out in the car I've noticed that when driving at approx 20 mph in 2nd gear the car seems to lose power, unless I put my foot down on the accelerator it regains speed, similiar problem at 30mph in 3rd gear. It's never done anything like this until recently. I've been running on fumes between fill ups recently, is this likely to be the cause and maybe some crap from the tank has gone through to the fuel filter or Carburettor. Or is the car dying a slow death considering its done 160k miles.
Thanks guys in advance for any help
Speed sensor, fuel pump / filter, clogged MAF or ISCV. Might be a process of elimination.
Did it do it suddenly or after a service?
Is the engine revving - eg is your clutch slipping?
Brake binding?
Need I go on - a bit more detail as I have covered fuel, engine, clutch and brakes - need to narrow it down a bit.
HTH
Brake binding?
HTH
I'll pick up a new filter and see if it rectifies it, if not I'll try the process of elimination as a few of you have mentions. Thank you.
big floppy donkey dick
if fuel filter doesnt fix it please dont do process of elimination,
fuckin hell lol
save yourself some money and take it to someone with PROPPER diagnostic gear, not a £50 handheld jobbie.
its your cash and your car, but never do process of elimination as its costly and silly IMO
fuckin hell lol
PS3 - MikeyRobbo
No lights on the dash? Might be worth seeing if you local garage will scan it for fault codes for you, i'd take it anyway just incase some fuckers took the EML bulb out! Shouldnt charge you no more than £20 quid for a scan! Saves buying a load of parts to just eliminate them from the fault.
ETA Beaten to it by Cossie Sean! Take it to a garage!
maybe i didnt make my post too clear. i meant that before getting into diagnostics check the obvious eg brake bind & clutch slip - process of elimination.
if deffo engine / ecu related from my experience of diagnostics are sometimes apita too. a fault that bad should manifest itself tho.
Testing the future
if it does it at the same revs then it helps you narrow it down.
blocked fuel filters show up when you need more fuel from them than they are supplying, that usually means high gears, high load and high rpm, not 1st and 2nd gear.
binding brakes would affect everywhere. clutch slip is entirely different as engine revs rise without road speed increase. i wish people would engage their brains before spouting nonsense like that.
you sure it's not just misfiring as coilpacks can give that trouble?
best advice though is to get it diagnosed properly before spending on replacing parts, especially if you don't know much about these things.
Thanks all for your advice, it seems like when driving the car doesn't seem to be getting enough fuel, and seems like it loses power for a split second or 2, which makes me think it is in fact the fuel filter and wouldn't really suprise me if it was as like I said in an earlier post, in recent weeks the car has been running on fumes in between fill ups. It does occasionally happen at steady driving speeds, not just when reaching 20,30mph in respective gears. I've had a look in a haynes manual at the replacement procedure and looks relatively simple.
I drove the car this evening at a steady 30mph in 3rd gear and it seemed like it was shuddering then a sudden very very slight boost in momentum/power, personally seems like it's a fuel filter blockage. but as I said I'm no expert. One has been ordered and I'm awaiting its arrival, even if it's not the filter itself, it wont hurt to put a new one on there, as I'm unsure when the last time one was put on
Will pick up some sparks and pop them in and see if it makes any improvements.
