quick question about 02sensors
Ive fitted an rs2000 16v mk5 engine in my mk 4 escort cab. Its all running okish but as soon as i press the throttle right down when driving it splutters and back fires.
Its no where near as bad if i slowly put throttle on.
Lambdas are knackered and dont really want them on, so left them disconnected. Also removed egr, iscv, powersteering pump n have no cat as wont need one from age of car.
Would having no 02 sensors be causing this problem??
And can a tuner tune it so itll run right?
The very early mk5's didn't run cats they had a sensor for each downpipe pair before they join into one pipe, if your running the standard management then yes you will need to run the lambdas or your fuelling will be all over the place making it run like crap.
cheers
SMILER258
28-09-2015 09:04 AM
