Painting Problem?
Old May 22, 2012 | 08:44 PM
MrJayware's Avatar
MrJayware
Default Painting Problem?
Ive started painting my fiesta with normal cellulose grey primar and the first coat was fine but the second came up a bit rough. It feels like sand paper, like really bitty
Anyone know why this might be??
Old May 22, 2012 | 09:05 PM
Vann1992's Avatar
Vann1992
Dust in the air sticking to the paint?
Old May 22, 2012 | 09:13 PM
luke19790_3's Avatar
luke19790_3
what pressure are you using, also do you clean the gun after using it.
1980blakey's Avatar
1980blakey
Did you filter the paint before putting it in the gun?
Old May 22, 2012 | 09:17 PM
matts1's Avatar
matts1
was it painted in an area to hot? maybe dried as it hit the panel?
Old May 22, 2012 | 09:21 PM
dingla rs's Avatar
dingla rs
can be few things ,if first coat was fine ,either the air cap holes are blocked ,air pressure down ,standing to far off panel or its drying to fast panel hot ,even so it will sand down anyway
Old May 22, 2012 | 09:22 PM
MrJayware's Avatar
MrJayware
Im not sure on the pressure it says 90psi on the compressor but it doesnt feel that powerful, I didnt filter is as it seemed really thin and i have to adimit it was drying rather quickly. By the time i'd done a whole layer the place where i started was already dry..
Old May 22, 2012 | 09:32 PM
luke19790_3
using 50/50 mix?, i normally use 60psi.
Old May 22, 2012 | 09:35 PM
MrJayware's Avatar
MrJayware
Yeah ive been using 1:1 or as close as i could get it
Old May 22, 2012 | 09:54 PM
dingla rs's Avatar
dingla rs
in this weather it will do as the thinners will evaporate fast
Old May 23, 2012 | 01:30 PM
ermir's Avatar
ermir
FOCUS
Definitely the pressure!!! Or u just kept the pistol to for from the car!
Old May 23, 2012 | 01:38 PM
E980VTJ's Avatar
E980VTJ
if you sand use alot of water
Old May 23, 2012 | 02:28 PM
ermir's Avatar
ermir
FOCUS
Also have to leave the sand paper in water for 1 or two hours. use no 2000 sandpaper. than continue with abrasive paste.
Old May 23, 2012 | 02:29 PM
durham fiesta's Avatar
durham fiesta
sounds too me like your standing too far away from the panel , possibly combined with the current heat .
Old May 23, 2012 | 03:06 PM
E980VTJ's Avatar
E980VTJ
whats the optimum temp,always thought it was cold pannels that were a pain,no expert by the way done a few of my own bits with 2k in a can and used a halogen heater and they always come out with a nice shine ,used 1500 grit on the top coat then laquered but 2000 grit would be better,learning every day off this site,also do you flatten the primer,I always have but not sure if your ment to,
E980VTJ's Avatar
E980VTJ
also I spray around 10 inches away is this correct?
Old May 23, 2012 | 03:09 PM
MrJayware's Avatar
MrJayware
The last time i painted was beginning of feb but it was inside a cool workshop aswell. Ive been wet and drying with 500 grit and its come up really smooth, and i was standing about 30cm away from the panel i was painting..
Old May 23, 2012 | 06:41 PM
Mats1985's Avatar
Mats1985
Pressure coming out of the gun should b no more than 2bar 35psi else will go on to dry a gritty plus don't paint panels etc over 30c try get them below around 25-27ish also when dry dust some arosol different colour to the primer then wet flat the panels wiv a block wiv 800grit paper
Old May 23, 2012 | 06:43 PM
Mats1985's Avatar
Mats1985
4got to say the reason for the different colour aerosol dusted on is to act as I guid coat block panels down until all the dusted aerosol is gone that's when you no the panel is straight and u don't go to far or not enough
Old May 23, 2012 | 06:51 PM
E980VTJ's Avatar
E980VTJ
good tip
155lee
Oct 27, 2015 04:55 AM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
routemaster
Sep 7, 2015 05:27 PM
hopper350
Sep 4, 2015 12:53 AM
