Braided Teflon Hose Cutting ?
T34 just kicked in Yo
An anle grinder blade, the thinner the better. Dont use a hammer and chissle, there are a few guides on the internet that tell you to use a sharp chissle and hammer through it, if you do it splits the sides of the teflon when it mashes it down before it cuts through it no matter how sharp, hard or fast you hit it.
A chisel? On a metal braided hose?? Some people should not be let near tools.
Get a cutting disc on a little 4" grinder and tape up where you want to cut and it will come out perfect.
I work for Goodridge and its usually cut on a saw with a super sharp thin metal blade. When i have to make lines up away from work i always wrap it with masking tape and use the thinnest cutting disc i can find in an angle grinder as others have said. That is the next best way in my opinion ![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
Although maybe i should do it properly and get a huge great chisel and a big hammer
