General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
Ok thanks, the box was recently swapped on my saph and the mechanic said he thought the two pieces (splined section) should have mated up further, I think the gearbox might be off an escos, but I checked it against the old box and another one I have and the output shaft to the rear prop all look the same length, I was informed the escos one is different to the saph (with the escos flange being shorter?)
the actual front part of the props are the same just the doughnuts are different
Not sure that's right. The thick donut has a bush for the spigots on the prop and output shafts, but the thin donut allows the shaft to go through and slip over the output shaft.
