Heater problems
Old Apr 25, 2012 | 03:23 PM
Fordmad!'s Avatar
Fordmad!
Default Heater problems
Having problems with the heaters in my xr3i. They put out good hot air within a few minutes usually but all of a sudden have stopped getting hot.
Driving for about 12 miles today and they suddenly went hot then cold again! Don't think its the matrix as they are usually really warm.
I think its the thermostat alothough thats only a year old. Also noticed fans are on when engine isnt really that hot.
Am i right in thinking its the thermostat???
Old Apr 25, 2012 | 04:03 PM
david 100's Avatar
david 100
Make sure you have the correct water level in the expansion tank, i am sure you have checked this or you could have a air lock.
Old Apr 25, 2012 | 04:10 PM
RS500/364's Avatar
RS500/364
also leaves getting to the heater matrix !
Old Apr 25, 2012 | 05:25 PM
Fordmad!'s Avatar
Fordmad!
I thought it might of been blocked/air locked etc but with the fans kicking in more then they should i thought thermostat to start with
Old Apr 26, 2012 | 04:26 AM
Take the pipes off the matrix and stick a hose pipe in the heater matrix and flush it out. For a few quid i would be trying a thermostat.
Old Apr 26, 2012 | 05:58 AM
Fordmad!'s Avatar
Fordmad!
So the two pipes that go to the bulk head in the middle?
Old Apr 26, 2012 | 12:19 PM
martysmartie's Avatar
martysmartie
Could be the thermostat, the easy way to confirm is to look and see what the temperature gauge is telling you, if the stat is stuck open it will run too cool.
Although for the fans to be activating would generally mean it is doing the opposite, i.e. overheating, thus your would have heating!
Don't just assume it's one single problem, it may be to completely different problems.
Martin
Old Apr 27, 2012 | 11:22 AM
Fordmad!'s Avatar
Fordmad!
Well for a week or so the gauge stayed really low and now it reads just under halfway ish which i take as normal.
Heaters seem to be cold then hot etc
Dont think its overheating think its the thermostsat playng up so will change this and go from there.
Old Apr 27, 2012 | 01:42 PM
david 100's Avatar
david 100
Cant you get someone who knows about cars to have a look,should be easy to find the problem.
Old Apr 27, 2012 | 01:52 PM
Fordmad!'s Avatar
Fordmad!
I no abit but with the weather atm i can't look at it yet. Just getting peoples opinions so it'll be easier to find the problem
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
