efi on zetec bottom end help
a friend of mine has a mk3 escort with zetec bottom end running frst management
the problem he is having is he carnt rev past 4k
im thinking it has the wrong flywheel on as it has a zetec one or are the pick up points on the zetec and frst the same?
if not what would stop it reving past 4k, everything has been changed and double checked and i can only see it being flywheel now
but want to make sure before i have to take gearbox off and swap everythig over
Balls Deep!
If it's running a BC gearbox then it will have a CVH flywheel, even if it's not the CPS is in the same place so no it's not the flywheel.
What exactly do you mean by won't rev past 4k... Is it just holding back, is it like a rev limiter?! Bit more info please mate.
