Corsa worsa....
Old 28-02-2005, 10:20 AM
jamieslittleracer
jamieslittleracer's Avatar
Default Corsa worsa....
look.... ive been looking everywhere and this one is in my town!!! its got really low milage, the bumpers are really icky and off colour but as in my other post i can get them sprayed properly... what do you think??
i know its not a ford, but its jsut a run around... im only 19 so plenty of time for proper cars when i leave uni!!
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MEWA:IT
please dont slate it just cos its not a corsa.... productive criticism is very welcome tho
katie xx
Old 28-02-2005, 10:23 AM
Chipperx2
Chipperx2's Avatar
err I'm 18 at uni, and I have a 1.6 escort
SRI's are ncie cars tho, I wouldn't have one. But in the famous words of George Dubya "Its your money, your paid for it"
Old 28-02-2005, 10:40 AM
dvid
dvid's Avatar
Im at uni and have a Escort GTI - well not for much longer
Looks good enough as a run around...
Old 28-02-2005, 10:42 AM
fad
fad's Avatar
Its a nice clean run around by the looks of it. doesnt say whether its the 8v or the 16v? Guessing 8 Valve by the year etc. Bullet proof and wont cause you much grief. Parts are also cheap and perfomance is adequte. For a run around you cant really grumble
Old 28-02-2005, 10:45 AM
jamieslittleracer
why would the 8v be like a sloath?? i assume it will be 8v as the 16v usually is advertised as that...
and about the uni thing... u guys dont have make up etc... to buy!! hehe.... its my first insurance as ive been a named driver up till now so no NCB and i dont want to be totally broke just for the sake of getting a better... better to build up NCB and more experience then when i can afford to get a decent car i can
katie x
Old 28-02-2005, 10:53 AM
xrsi
xrsi's Avatar
its an 8v as the 16v were the very very late SRi's or sports as they evolved into!
they are good little cars, mate had one and it was as quick as the 16v sports!
bits to watch for are rust around the spoiler at the bottom (if you look at the tailgate it rusts between the very lowest point of the spoiler and window on each side, this is due to the spoiler trapping rust under it and it eats it way out over time! if you can see rust bubles it will be alot worse under the spoiler!
not much else goes with the 8v compaired to 16v's!
just use common sense when looking at it and if things dont look right for millage etc walk away as there are pleanty of corsa's to be found!
Old 28-02-2005, 10:58 AM
jamieslittleracer
hey thanks for the advise... im not too bothered about it being that fast.. as long as im not overtaken by my grandparents im happy... hehe
my dad is going to see it for me and if it looks good ill go down and see it.... ill let him know about the rust.... the guy said for insurance he didnt want anyone else to drive it but my dad is insured on otehr cars and i want to see what the clutch and brakes are like as i dont want to buy a car that ive got to go straight out and sort out...
thanks
katie x
Old 28-02-2005, 11:01 AM
The 8v motors are a lot slower than the 16v ones, really big difference, and the 16v ones are much more tunable too, i know a guy with 180bhp N/A from a 1400 16v vauxhall motor for example.
Check the usual things, like rust, especially round the rear end as its a favourite on corsas.
Fantastic choice of a first car i reckon though, for 200 quid brand new you can buy a set of 288mm disks and calipers which will see you outbreaking a cossie into a bend, few hundred quid for a suspension kit and you'll be handling well too.
If you can get the insurance on an engine swap, for a few hundred quid you can chuck in a 2.0 16v XE, which will give you a power to weight ratio as good as a standard cossie, for a grand you could have it running a lightly modded 2.0 16v turbo, which once moving will happily keep easily with a stage 3 cossie.
Vauxhall parts are SO interchangeable that it means loads of cheap upgrades can be had
Old 28-02-2005, 11:09 AM
jamieslittleracer
tehehe.. lol i think for the time being ill stick with its normal engine.. maybe in the future!!! thanks for the advise on brakes i might look intop it.. always reassuring when u know ur car will stop!! hehe
Old 28-02-2005, 11:12 AM
Other cheap brake conversion is a set of secondhand 256mm ones off a calibra or similar, 50 quid should secure a set for you, and they take about 20 mins total to fit, really is a piece of cake.
Reason for going for those is they will fit under 14" rims still if you keep the standard wheels.
The 288mm need 16" rims really (although some 15" rims will fit)
Old 28-02-2005, 11:15 AM
jamieslittleracer
wow... i think if i get the car i will need a refresh on this info!! hehe im going to put my 15s on the car... therye my special wheels, so much so i limited my choice of car so they would fit which is ridiculous as theyre not expensive alloys or anything.. jsut sentimental!!
ill be running to you for help hehe... thanks for the info!!!
katie xx
Old 28-02-2005, 11:17 AM
What car are you current 15" wheels from?
To fit a corsa they need to be 4 stud, 100mm PCD and an offset of around 49mm
(although on 15" you can get away with as little as 40mm potentially you will find it adverserly effects the handling if you do, causing excessive bump steer)
Old 28-02-2005, 11:20 AM
jamieslittleracer
yeh they will fit... hehe... i did extensive research cos i didnt trust one source, theyve been on my boyfriend nova and my ibiza but only a month on each... ill go and get them fitten tho cos that plastic bit ( cant remember what its called that sits in teh central bore) fits my ibiza so i need new ones.... and plus ive been in a car when a wheel comes off so id like them fitted nice and tight hehe!!
Old 28-02-2005, 11:22 AM
If they fitted on a nova, they will fit on a corsa.
If they were on an ibiza though, unless they were fitted with spacers they must have looked really gay, as they would have sat too far into the arches as they use a much smaller offset.
Old 28-02-2005, 11:26 AM
Chipperx2
Chipperx2's Avatar
as long as you don't do this to it
jamieslittleracer
no they were ok.... anyway i dont ahve the ibiza anymore... so it doesnt matter...
Old 28-02-2005, 11:28 AM
jamieslittleracer
toh thats a shame, that car is everything i want my car to be! ive always wanted 6 exhaust pipes tehehehe!!!
seriously... apart from my wheels the car is staying as it is on teh outside!!!!!!
oh my god ic ant get over that car... hehe....
Old 28-02-2005, 11:31 AM
check the offset then, cause if they fitted on an ibiza without looking too far in, i suspect they may be a smaller offset than the 49mm your corsa would want to handle correctly.
PS
Its written on the back of the wheel, it will say something like
ET38
ET49
Old 28-02-2005, 11:54 AM
jamieslittleracer
bugger.... i got it into my head they were et45 but if i remember rightly theyre et38.. theyre at home but ill get my sis to check... corsas min is 42.. but cant u go 5 odd mm out of the offset?? do u reckon they will fit?? ill be gutted if they dont... i dont know why they went on the nova they have the same offset as corsa.. can u use spacers?? thats why they fitted my ibiza so well hehe
katie x
Old 28-02-2005, 12:22 PM
jamieslittleracer
no power steering...
i forgot about that....
oh nooo... waht do i do!!! i drove my boyfriends car once without power steering and i got arm ache heeh!!! all my cars have had power steering...
do i still go for it without an air bag or power steering or do i look into anotehr car??
katie xx
Old 28-02-2005, 12:24 PM
Phil
Jeebus
Phil's Avatar
I bought a 400 brake 2WD cossie at the end of my first year at uni
You can do better than a Corsa
Old 28-02-2005, 12:32 PM
jamieslittleracer
im going third party and dont want to spend more than £2000. i know i can do better... but for some strange reason i quite like this car....
i dunno im in a hurry i need on before i go home in 4 weeks....
its not forever.... i cant find anything i really like tbh..
katie x
Old 28-02-2005, 12:33 PM
RichardPON
RichardPON's Avatar
Me too
Ah, the old days of student loans
Old 28-02-2005, 12:35 PM
jamieslittleracer
Me too
i dont get much student loan cos of my dads pay and cos im doing physio.. besides if i wanted a good car my dad would buy one but i want to get a cheap run around third party on my own insurance
Old 28-02-2005, 12:36 PM
If they are ET38, they may just about fit on, its a bit of a "pot luck" thing as there is about 6mm of allowed misfit on the rear beam during manufacture at vuaxhall, so they will fit some corsas and not others.
If they were on the ibize with spacers then they are probably far higher than 38mm anyway, so you may be fine.
You cant use spacers on the corsa as the problem will be they stick too far out and spacers can only push the wheel further out not pull it back in.
Old 28-02-2005, 12:42 PM
jamieslittleracer
they didnt have spacers on the ibiza... just found out the corsa doesnt have power steering not sure if i want it now.. im not used to old cars!!! hehe..
thank u so much for ur advise!!
Old 28-02-2005, 12:52 PM
xrsi
xrsi's Avatar
right, the 8v is NOT slower than the 16v!
a mate has had a couple of 16v corsa and they have been slightly slower than the 8v
the 16v are ecotech and are for economy and emmissions rather than power, to tune them, the EGR needs removing, the valves need opening up and then lnlet needs changing to a power box! (fancy name for a plenum!) however i do agree with you i feel that the ecotech engines are far more tunable than a red top or such like due to the design that has gone into them (just look at zetec tuning now!)
sorry mate not being funny but if you can do an engine swap using an XE for couple of hundred then i think you are scrimping somewhere! All the uprated parts alone such as mounts etc are more than that! then there is the engine which alone fetches anywhere in region of £250 - £500! oh and you got the problems of either modding the bulkhead to fit the origionbal power cap on the inlet of get one made to fit into a corsa!
try doubling that figure for the c20-let engine mate as the engine alone brings over £1k! then fitting etc! all not cheap with alot of bits needing custom making!
also the brakes which are commonly used are the 16v astra GTE ones or the astra GSi ones as these fit straight on! i think you will find the bigger ones off a cav or calibra are 5 stud so do not fit!
you can get the PCD of alloys etc altered to a certain degree, places advertize in the back of motorsport mags etc that offer this service however it prob wont be cheap and im not sure how far you could go with it!
Old 28-02-2005, 12:59 PM
XRSi
Trust me on this one!
Its VERY realistic to do it for a few hundred quid.
As ive done both C20LET and C20XE conversions into novas, i suspect that i know far more about it than you do!
with regards to the brakes, ALL cavs and calibras that have 256mm disks are 4 stud, only the V6 and turbo models had 5 stud, and they have the larger disks (288mm)
Again, ive done these brake conversions on several cars, including converting my rwd mid engined nova to 288mm 5 stud all the way round recently.
So again im pretty confident i know EXACTLY what im talking about!
Old 28-02-2005, 01:01 PM
jamieslittleracer
boys boys... even if i get the car i wont be touching it as the purpose of this car for the timebeing is A to b, boring as i may seem!!
what i want to know is am i going to struggle loads with no power steering??? im just not used to it.... i gues ill get used to it but its not much fun to drive is it??
katie x
Old 28-02-2005, 01:02 PM
Phil
Jeebus
Phil's Avatar
Me too
I still get the student loans
Only these days they take me from £2000 overdrawn to £1000 overdrawn for about 10 minutes
Old 28-02-2005, 01:05 PM
Katie, the corsa sri has a fairly low ratio rack anyway you wont really struggle without power steering.
Its only parellel parking you will even notice it in fact, once you are doing more than about 10mph its irrelevant
Old 28-02-2005, 01:06 PM
RichardPON
RichardPON's Avatar
PMSL
Katie - that seems like a very sensible way to go
Old 28-02-2005, 01:10 PM
jamieslittleracer
ahh im a pro at parking... hehe... thanks for the advise
Old 28-02-2005, 01:35 PM
ALL girls should drive cars with no power steering.
My ex had a mini with a quick ratio (hard work) rack and 7" wide alloys, and my god she gave good handjobs after she had been driving it for a while
Old 28-02-2005, 01:52 PM
Chipperx2
Chipperx2's Avatar
@chip
Old 28-02-2005, 01:56 PM
chiz
chiz's Avatar
wat groups the sri insurance wise????
katie please by a ford
wat bout a mk2 fiesta, or mk3.
or a mk4 escort. bonus or popular??
im 19 and @ uni and av got 3 motors........ dont each much tho, or go out, hmm.
i c yr point
anyways please by a ford
u wont regret it!!!!!!!!
Old 28-02-2005, 01:57 PM
XRSi, are you aware that i fitted the engine and nitrous kit etc and set it up in my nova with which i won overall the nova shootout at the pod last year?
(see my sig for a video of it in action)
I honestly do know EXACTLY what is involved in the conversion.
Pop over to www.migweb.co.uk and ask whats needed to fit an XE into a nova or a corsa etc if you dont want to take my word for it!
Old 28-02-2005, 02:03 PM
jamieslittleracer
i c yr point
hehe not sure what insurance bracket but i can get insured for £600 third party which is pretty good.. for me!!
i would have got a mk4 fez but for personal reasons i wont ever be buying a fiesta... so no ford for me!! maybe in teh future i will get one but not right now.
Old 28-02-2005, 02:05 PM
Corsa is a better car for the money than a fiesta, vauxhall engines of that era are far better than ford ones.
Quick Reply: Corsa worsa....
