Stupid question
Old Apr 21, 2012 | 10:36 AM
SaphCos4x4_Dan's Avatar
SaphCos4x4_Dan
loves a good ham shank
Default Stupid question
Can I grind out a slight bit of rot on a chassis leg, treat it and bog/paint the surface to leave it looking original instead of welding a nasty plate over it?
It's not deep enough to require a strengthening plate hence the stupid question
Old Apr 21, 2012 | 11:21 AM
rsminter's Avatar
rsminter
why not cut out the rot, make a plate that fits tight in the hole, weld it then grind the welds flat treat and paint it...invisible repair, no rot job done
Old Apr 21, 2012 | 12:03 PM
SaphCos4x4_Dan
The on
Old Apr 21, 2012 | 12:05 PM
SaphCos4x4_Dan
The only thing with that, is i'l be cutting out a lot more good metal than actual rust!
Old Apr 21, 2012 | 04:22 PM
Eigdoog's Avatar
Eigdoog
ą§~Quadzackular~§ą
Pictures?
Old Apr 21, 2012 | 04:38 PM
V6 Ste's Avatar
V6 Ste
Cut out all the rot and a bit of good metal. Make a plate up that fits the hole thats of equal or better thickness and seam weld it. Grind welds flush, seal it and its as good as new
Old Apr 21, 2012 | 04:47 PM
BRAMMER's Avatar
BRAMMER
Get a wire bit on a drill/grinder first before you make sure it's actually eating into the metal as lots of surface rust looks really bad but once you get underneath it's solid - i would never stick bog on the underside always cut out
Old Apr 21, 2012 | 08:49 PM
SaphCos4x4_Dan
Honestly it is really not bad and deffinatley doesn't warrant cutting out, I'm just being really picky but I want it to look perfect
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
locum8
Oct 1, 2015 01:50 PM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
