Cosworth Lambda Sensor & Closed loop - few questions
Old Apr 19, 2012 | 08:48 PM
Mungus's Avatar
Mungus
Default Cosworth Lambda Sensor & Closed loop - few questions
Evening all,
So I am just about to change my exhaust on my Saph which is a 4x4 with 2wd conversion. The current system is a 2wd with a lambda boss welded on the down pipe.
The system which will replace it is a mongoose 4wd full system which I noticed tonight has no lambda boss. Not a big deal - will get one fitted prior to going on...in fact was going to install a second for AFR metering
....... but got me thinking:
1. Suprised being a 4x4 system that the Mongoose doesnt have the lambda boss installed
2. Pretty sure my car had a lambda installed from factory being a 1992??
3. With my car having a lambda, does this mean I have closed loop? How would I otherwise tell if I have this feature??
4. Back to my original plan - installing the additional boss, where is best to have this done??
Huw
Old Apr 19, 2012 | 08:51 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Originally on the 4x4 Greentop engines, the lambda boss was integrated into the turbo housing.
Best place to install it now would be around 2" to 3" back from the flange where the downpipe meets the turbo as it will be in direct exhaust gas flow there and not catch on the heat shield if you still have it.
Old Apr 19, 2012 | 08:58 PM
Mungus's Avatar
Mungus
Brill - thats exactly where it is on the system thats being removed
Any ideas on the other questions?
Huw
Old Apr 20, 2012 | 01:45 AM
axelriet's Avatar
axelriet
2. Yes.
3. Yes, if you have the factory chip. With 3rd parties all bets are off, and keep in mind that closed-loop with on/off sensors only works at idle and when cruising. The ECU runs in open loop at high load.
manuel boeckx
13
Oct 3, 2015 02:29 PM
Anutternutter
24
Aug 31, 2015 01:24 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Aug 14, 2015 07:29 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
